BCS String Trimmer Attachment ?
/ BCS String Trimmer Attachment ? #1
PhilG327
La Farge, WI
BCS 852
Has anyone bought or built a string trimmer attachment for a BCS? Something like the DR Trimmer series? I've found as I get older, wielding a gas string trimmer has gotten just too much for me. Weak arms I guess :)
/ BCS String Trimmer Attachment ? #2
Have you ever used one with a full harness like this one. Much better than the single harness.
As far as adapting a walk behind it seems like a lot of power just to spin a plastic filament. I致e always thought a an electric 3-wheel bicycle could be adapted to hang an electric line trimmer off it for doing long fence lines. They make inexpensive walk behind string trimmers for $300 or less for the cheaper ones.
Thanks for the info JamesHW. I agree, using a BCS with 13hp is WAY overkill for a string trimmer. I think the real problem may be that I bought a trimmer with a straight shaft and it places the cutting string at an odd angle for my back. Will have to see if it can be converted to a curved shaft. The harness looks like it might be a solution too, but I'd hate to order one and find out it didn't work for me. Will have to see. Thanks again.
/ BCS String Trimmer Attachment ? #4
The harness makes a big difference. I’ve used them on my last 2 straight shaft trimmers with handle bars.
/ BCS String Trimmer Attachment ? #5
I have a Cub Cadet walk behind string trimmer that I use to trim around the electric fence around the garden that works good I have a Grillo g85d I think a string trimmer attachment would be overkill
/ BCS String Trimmer Attachment ? #6
I recently bought one of the Cub Cadet machines too. It is a bit harder to push than I expected. It's a fairly heavy machine - think push mower more than string trimmer. It is a strong machine though. I managed to snatch a ground wire completely off the phone jack on the side of the house and wrapped that thing around the dang trimmer head before I quite knew what happened. And that was a 12 guage solid copper wire. The string for the trimmer is actually lengths about 12" long and the diameter of a wooden pencil.
/ BCS String Trimmer Attachment ? #7
I use mine mainly for mowing under the electric fence around my garden. It will eat the plastic step in post I use between the steel corner post. I believe it uses. 165 line . I have no complaints with the machine ,but if I had it to do over I would probably not buy it again. I can mow close enough on each side of the fence to only have 8-10 inch strip. I can do that with my stihl weed eater and it doesn't destroy my plastic fence post
/ BCS String Trimmer Attachment ? #8
Hello Phil,
I am in the same boat as I have a pacemaker now GGGGRRRRR and I cannot use gas powered tools. The stihl corded weed wacker is $130.00 plus sales tax on the this side of the Mississippi. It uses the .080 line so it cannot be all bad. I am not sure if the battery powered stihl weed wacker uses the .080 line.
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
2022 Caterpillar 289D3 Rubber Track Skid Steer (A64047)
2022 Caterpillar...
2013 Kubota BX2370 44in 4x4 Compact Utility Tractor Mower (A61572)
2013 Kubota BX2370...
MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
500 BBL FRAC TANK...
Electric Tricycle (A64194)
Electric Tricycle...
