BCS pto gear lube
   / BCS pto gear lube #1
van1
Ohio
YM2210
I'm working on the shift mechanism of the pto. What type of lube is used for the pto coupling? Can't tell what was on the coupling. It was contaminated with water and rust. The tiller would engage, but wouldn't disengage. Cleaned everything up and sanded and polished mating parts. Now need to lube and put back together. Great tiller. I've had it for over ten years. This is the first problem I've had with it. Self inflicted. I was leaving it out in the rain. By the way, It's a 205.
   / BCS pto gear lube #2
Hi Van,
Any multipurpose grease will work in there. Just pump the hole nearly full and clamp the tiller back on. 205s are nice little machines.
Bill in WI
   / BCS pto gear lube
That's just what I did. It's works like a dream.
2013 FORD F550 SHUTTLE BUS (A52576)
2013 FORD F550...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
PENDING SELLER CONFIRMATIONS (A52576)
PENDING SELLER...
2025 New/Unused Wolverine Brush Cutter (A51573)
2025 New/Unused...
LOT LOCATIONS (A53426)
