BCS PowerSafe Rubber Bits in Filter
/ BCS PowerSafe Rubber Bits in Filter #1
Tandem
Wet Coast, NZ
Pasquali XB40
I just removed the PowerSafe filter from Pasquali XB40 (BCS 740) and found few pieces of rubber sticking out of the filter holes. Any ideas what these chunks of rubber could be?
/ BCS PowerSafe Rubber Bits in Filter #2
Looks like some kind of seal - I think I would get ahold of your dealer or BCS and see if their tech guys could help. Good luck.
/ BCS PowerSafe Rubber Bits in Filter #3
Is it rtv gasket maker or the Silicone anti-drain back valve from the filter...
/ BCS PowerSafe Rubber Bits in Filter #4
/ BCS PowerSafe Rubber Bits in Filter #5
Interesting.
As the oil to be filtered goes in through the outer holes then out the center hole, I am guessing it is gasket sealant that was over applied?
You could cut the filter open and see if there is any debris inside, but I doubt it.
Cheers! :drink:
There were few more bits of the same soft rubber or silicon inside the filter.
Dealer said that it is excess gasket from the inside of the rear transmission plate and that this is normal and not an issue to the machine.
/ BCS PowerSafe Rubber Bits in Filter #7
Glad to hear it was a minor issue and the dealer was able to help. Enjoy that BCS - they are great machines!
*Selling at Royal Auction Tampa, FL Location* (A59231)
*Selling at Royal...
2023 BOBCAT T770 SKID STEER (A62129)
2023 BOBCAT T770...
2013 WESTERN STAR 4900 SB MID ROOF SLEEPER (A63569)
2013 WESTERN STAR...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2003 International 4300 Flatbed Dump (A62613)
2003 International...
Altec Digger Derrick Hydraulic Boom (A61572)
Altec Digger...
