BCS oil bath air filter cleaning …
   / BCS oil bath air filter cleaning … #1
Delcho Valkov
BCS 780 HQ
Hey everyone.
I have a BCS 780 two-wheel tractor that have been working in extremely dry and dusty conditions for the past several days and the air filter is literally black. It has an oil bath air filter that whenever dirty needs a clean and new oil filled to a certain point. I have two questions:
1. What type of oil should I use there (I read through the manual but that is the ONLY type of oil that is NOT mentioned anywhere).
2. What is the best way to clean the steal mesh when it is so dirty?
Thanks in advance!
All the best,
Delcho
   / BCS oil bath air filter cleaning … #2
Take the mesh and soak/suspend it in solvent while agitating it occasionally, as for the oil, use the same oil as you put in the engine.
That is how I clean the oil bath used on the old Ford tractors I work on.
Thanks for the info!
What kind of solvent do you use?
   / BCS oil bath air filter cleaning … #4
I use a can of gasoline as the solvent and slosh it around with a couple of changes till it stays clean. I have no idea what that unit would recommend for oil, but the older tractors always called for sae 30 oil the reasoning as I understand it was that thinner oils could be drawn up and into the intake during full throttle operation. That said I did and do use 15W-40 in mine as 30 is more difficult to find.
   / BCS oil bath air filter cleaning … #5
I have a tractor with an oil bath and do what LouNY does, except I have enough suspect diesel around I use that to clean with. I would be careful using very strong solvents on unknown materials. I also just fill the base with 15W40 although 30W was originally spec'd (in the dark ages). No problems after years of doing it that way. Hadn't thought about our "new" oils generally tending to the thinner side today...
   / BCS oil bath air filter cleaning … #6
One of my most used things is a 20 gallon solvent capable parts washer. Was rather inexpensive compared to others that were capable of handling petroleum based solvents without wrecking pump usually the impeller. I then place the clean foam element in a plastic bag and add oil they do sell foam air filter oil by the quart specifically, I don't buy aerosol foam oil anymore. imo it's more tacky then motor oil , I work the oil and element around in the bag thoroughly and gently squeeze excess oil off upon removal in the bag this method has worked well for me for over a decade and it's relatively mess free compared to previous methods I've used. Inspecting the element for perforations determines if I replace it. I use my method to maintain quite a few rused and abused elic lawn tractors and ATVs without problems. Pictured is my solvent resistant 20 gal parts washer and cleaned foam filters from ATVs.
   / BCS oil bath air filter cleaning … #7
Many years ago we used kerosene.
willy
   / BCS oil bath air filter cleaning … #8
For solvent I use kerosene, diesel or gas. Basically whatever I have handy
   / BCS oil bath air filter cleaning … #9
For the filter oil I would use the same as the engine oil
willy
Thanks all for the answers. This was very helpful!
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
378488 (A51573)
378488 (A51573)
2018 John Deere 460E Articulated Dump Truck (A53472)
2018 John Deere...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
2012 International ProStar Sleeper Cab Truck Tractor (A51692)
2012 International...
2021 Chevrolet Silverado 4500HD / Silverado 5500HD Flat Bed, VIN # 1HTKJPVK3MH814615 (A51572)
2021 Chevrolet...
