Bcs motor swap
/ Bcs motor swap #1
jperry507
Westport, MA
Hello everyone,
I am swapping out an aftermakt Briggs 16hp vanguard motor for a new 13 hp Honda from earthtools for my bcs 850.
The clutch has a set screw and the clutch housing has a notched area which matches the notched area on my conversion adapter. Together these notches accept the set screw on the clutch in the six o'clock position. However when I try to bolt the Honda onto the conversion adapter, the bolts do not line up with any of the honda's unless the Honda is in it's side. I don't understand the set screw in the end of the clutch. Can someone explain it to me and how it should fit as the tractor is reassembled?
/ Bcs motor swap #2
Hey Perry,
I think the notch should be at the 1 o'clock position. Give me a call tomorrow at 6oh8 7three2 5ohfive3 and maybe I can walk you through it.
Bill
1043 (A60430)
1043 (A60430)
2021 Bobcat T76 Compact Track Loader (A64047)
2021 Bobcat T76...
1996 Vermeer V-3550 Ride-On Trencher (A61572)
1996 Vermeer...
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
iDrive TDS-2010H...
TAKEUCHI TL230 SERIES 2 SKID STEER (A64279)
TAKEUCHI TL230...
