BCS Engine Experiences and Thoughts
   / BCS Engine Experiences and Thoughts #1
wstr75
Puttering around with mechanical equipment is is one of my pursuits. I bought an 853 with 12 hp Lombardini diesel new about four years ago, a badly in need of repairs 710 with a Honda 8hp about five years ago and an early vintage 737 with a dead Acme engine about three years ago. I don't use the 710 much because single speed BCS tractors are not much fun. It takes too long to get from the shed to the garden, across the yard, etc. The 737 was repowered with a 13hp Honda and is a joy to use with the power wheelbarrow and sickle bar mower as its easy to actuate reverse lever makes manuvering forward/backward around trees and ditch banks easy.
Here's my take on engines for BCS tractors. The Lombardini diesel is powerful, thrifty with fuel, loud and a bear to hand crank when the engine is cold. Honda engines hand crank easily, are quiet and thrifty with fuel.
The past two weeks I've let a handyman down on his luck clear the brush out of a nine acre parcel. He started out with the 853 running a 34" Palladino flail mower. The first day he was mowing kudzu vines when a vine snagged on the reverse lever, at the same time he slipped and the mower came back into him. He is okay but his knee hit the electronic controls breaking the key off in the electric starter switch, breaking the lower bolt holding the electronic key/starting/charging control flush with the fan housing. He saw where the key was broken off but was able to inset the broken key head into the control to start and turn off the motor charging/starting control. He kept running the tractor for several days and the vibration did a number on the wiring and starting/charging control such that no charging is taking place. Accidents happen and we are fortunate he is not hurt. However, I've not yet been able to get the charging up and running even after checking all connections in the multi-connection quick disconnect block. I'm figuring replacing the electronic key/starting/charging control box will also be in the $200 to $350 range. He made matters worse by operating the flail mower with missing "Y" blades. The flail mower got about ten years of wear and tear in one week. I have the parts for replacing the wear parts and bearings so it will one day be like new again as it is my go to mower around the garden and back field.
I love the diesel engine but the only time the full power provided by this beast is needed is when running the 34" flail mower in second gear in 36" tall, wet fescue. The next closest power hog is the 38" BCS lawn mower with bagger. I figure a 13hp Honda would power that mower quite well. Next down on the power need list is the Zanon 28" brush mower. I believe an 11 hp Honda would run it well based on how the Lombardini seldom barked when hitting heavy brush yesterday. The rest of my equipment - Berta rotary plow, Bios 80 chipper, 26" tiller and 30" sickle bar mower could be powered by an 8 hp Honda. The chipper can be a power hog if one is trying to quickly process stuff, but if one is patient and lets it stay in the "fast flywheel" zone by avoiding choking the chipper, 8hp probably is plenty adequate.
Yes, the diesel can allegedly handle greater side hill slopes without oil starvation, but that alone is not a good enough reason for purchasing a diesel. If I had it to do all over again, I'd go with a non-electric start 13 hp Honda or other equivalent 13 hp to 14 hp easy cranking gasoline engine. Having said all this, the Lombardini is going to get restored to like new condition sometime later this year and will likely only leave my garage after I'm dead. My purpose in writing these thoughts is to provide information to anyone looking for real world feedback on electric start diesel versus manual start gasoline for powering various BCS/Other brand implements.
Bill in NC
   / BCS Engine Experiences and Thoughts #2
Hi Bill,
I agree with you on the horsepower requirements. The HP requirements as stated by dealers tend to be conservative in order to make sure a customer has power to spare and ends up happy with their machine.
When I had a 38 inch mower, I ran it for the first year on a 715 with 8 hp Kohler magnum and had no problems, except for the one slow mowing speed. Joel told me the Magnum would not run the mower. It did a fine job. After I sold that 715 and got an 850 with V-twin Briggs, the only advantage the 850 had was the better transmission with 3 mowing speeds and instant reverse. Mounting the Lombardini diesel engine in place of the V-twin made for a more reliable, more fuel efficient engine, but no better of a job mowing. The last year I had the mower, I got a Mainline BCS 735 that had been burned. I mounted an 8 hp Kohler Magnum and used it on the mower! I lost one working speed and instant reverse, but the 735 with 8 hp and taller tires was actually more pleasurable to run on the mower than the big ol' 850 diesel.
While you're right that 8 hp will power the BIO-100 chipper, I do like to have plenty of power to spare with the chipper. I can feed a little faster with the diesel on duty than I can with the 735.
The double rotary plow also benefits from full power - well mine does. I have a plow with a higher gear ratio than usual. It was made for slower RPM tractors and I can only run it 3/4 throttle.
It sounds like your Handyman might be down on his luck for not being very handy. A guy who runs my equipment like he ran yours wouldn't be around for very long.
Yes, he is an outdoorsman and is a good man, but has a limited sense regarding mechanical items. This is why I think a simpler hand cranked gasoline engine is better for everybody excepting the commercial gardening/farming folks.
Bill in NC
   / BCS Engine Experiences and Thoughts #4
A hand cranked Hazt diesel with automatic decompression
is an option.
Doesn't the Lombardini engine you own have a recoil start
with automatic decompression anyway?
_________________________________________________________________
Once you go flail you never go back:thumbsup::licking::drool:
Pronovost or not at all!!!:thumbsup::licking::drool:
Notice: TBN Members that own flailmowers for thier 2 wheel mules are automatically made members of the Flail Mower Nation.
2018 DODGE GRAND CARAVAN (A51222)
2018 DODGE GRAND...
THIS WILL BE A LIVE VIRTUAL ONLINE AUCTION! (A50657)
THIS WILL BE A...
2017 Snapper Pro 48in Zero Turn Commercial Mower (A49346)
2017 Snapper Pro...
2017 Nissan Titan SV Crew Cab Pickup Truck (A48081)
2017 Nissan Titan...
2025 Swict 72in Bucket Skid Steer Attachment (A49346)
2025 Swict 72in...
2008 Pro Pull Gooseneck Trailer (A50860)
2008 Pro Pull...
