BCS Clutch Adjustment
/ BCS Clutch Adjustment #1
jperry507
Bronze Member
Westport, MA
Hello everyone,
Yesterday I bought a used BCS 850, I can't wait to use it. It came with a power sweeper and a sickle bar mower.
There are a couple of small things that I need to fix (nothing major), but first I think I need to adjust the clutch. Whether I hold the clutch lever or let it loose the clutch is engaged. I followed the wire from the handle to where the clutch is, but my question is in what position is the lever in when the clutch is engaged?
Thanks for your help
~ Jim
/ BCS Clutch Adjustment #2
First off I have a lever on top of the handle bar which is red. The lever on the bottom is for the clutch and must be pulled up for shifting gears and let all the way down to engage the clutch.The red handle on top is for when you let go of the handlbars on purpose or maybe fall it shuts the machine off automatically. If your clutch is always engaed it definately needs some adjusting or maybe the cable is diconnected or broken.
I have to hold the red handle down to start the tractor.
If it was working properly when I let the black handle go down the clutch should be engaged, and when I squeese the back handle the clutch should release?
Thanks ~ Jim
/ BCS Clutch Adjustment #4
Yes, that is right Jim , the red handle has a rig that will hold it down untill it is started, sometimes I will use a rubber band to hold it down also. Have you had any luck getting your clutch adjusted?
I'll have a chance to work on the tractor on Thursday, and I will let everyone know how I made out. Thanks for your help!
Hello all,
I played with the 850 for a little while last night. This tractor is going to need some work done to the clutch. Last night I detached the clutch cable, put the tractor in gear, and tried to disengage the clutch by moving the lever on top of the drivetrain manually. I could not disengage the clutch.
I haven't yet decided if I am going to do the work myself or send it to a shop.
Thanks for your help,
~ Jim
/ BCS Clutch Adjustment #7
I have a 735 and the only adjustment I can find is on the cable, similar to a motorcycle clutch cable, the clutch fork comes out the top of the housing and the cable connects there. I don't have the red lever you are talking about.
I'll take some pics and post them here. As far as the BCS is concerned I am going to bring it to a dealer for the repair soon.
Jim
/ BCS Clutch Adjustment #9
I'm interested in how this red lever works, is it a forward/reverse lever similar to the old Gravely? Is there some adjustment for your clutch other than the cable?
/ BCS Clutch Adjustment #10
The red lever is separate from the clutch, but is on the same handle as the clutch and is connected to a 'kill switch'. The clutch lever is on the bottom and this red lever is on top of the left handle of the tractor. It is spring loaded so if you let go of the handle the engine dies. It's just a safety device.
/ BCS Clutch Adjustment #11
Oh, that red lever, I have the same thing, but it is black.
Seems I heard or read somewhere that the newer BCS models has something similar to a shuttle shift, for quick forward/back direction changes, is that true?
/ BCS Clutch Adjustment #12
I'm wondering if the tractor had been setting awhile and not used and the clutch may have stuck to the preasure plate , that sure sounds what might be your problem.I had that happen to a small farm tractor once that sat all winter without being used. I started it up and it took off clutch in or not .I'm guessing these bcs tractors must have a very similar setup.
Good Luck
HC
/ BCS Clutch Adjustment #13
I wonder if you ever got your BCS 850 cluctch fixed. I and working on one too.
/ BCS Clutch Adjustment #14
Here is a link to another BCS site where I describe un-sticking my BCS clutch.
Yahoo! Groups
I used my BCS several times since and the clutch works like new. I spoke to Bill at the BCS Shop and he said we should have the clutch engaged (transmission not turning position) when storing the tractor. This keeps the friction components apart and not able to rust weld together. I put pull the clutch lever up and lock it but leave the red lever up so as to not stretch the kill switch spring when in storage.
Bill in NC
/ BCS Clutch Adjustment #15
Well I had a time with mine. Water had worked it's way into the clutch housing and the Clutch was locked up good! The shade tree mechanic in me want to hit it with a hammer but the Machinist in me took over and I started to study how it should work. I removed the clutch and found a socket and oak board to protect the ends of the clutch. I clamped them down in a Bessey clamp and "POP" it came loose. While I was in the Clutch housing I found some 1/4" steel ball bearings. Any Idea what they are for?
Yup, got it fixed.
I took off the motor, and the clutch was stuck. Never park your BCS with the clutch engaged. a bit of rust had formed and was a pain to unstick. I used penetrating oil, a hammer and a vise.
~ Jim
/ BCS Clutch Adjustment #18
Yahoo! Groups
Bill in NC
I just used this as an excuse to SWMBO to make sure I now own enough attachments so that the BCS is in use year round...:D
/ BCS Clutch Adjustment #19
You wouldn't have known since you are a new owner with an already stuck clutch but I am pretty sure the owner's manual strongly cautions about storing the tractor with the clutch engaged.
After reading about so many problems I'm glad I developed my good habit early on with mine.
/ BCS Clutch Adjustment #20
Umm, the BCS service guide link above has the following sentence which tells us to disengage the clutch (squeeze the lever). Note the reference to using the locking tab. I think the Italians see disengaged as meaning the drivetrain is disengaged from the engine. We Americans tend to see the clutch being pushed in as engaged.
10) Instruct the customer that to prevent this from happening again, always lock the clutch lever
(Ref.#6) in the upright, disengaged position, using locking tab (Ref.#7), when storing the unit.
Take a close look at the drawing in the lower right corner of the link. It shows the clutch lever squeezed and the locking tab holding it in during storage.
http://bcsamerica.com/pdfs/serviceinfo2-6clutchstuckinengaged.pdf
I bought a BCS with a stuck clutch and can tell you the cone clutch design is simple but it does leave metal surfaces pressed-up together when the clutch lever is in the power transfer mode (lever in run position).
Bill in NC
