BCS CHipper/Shredder
/ BCS CHipper/Shredder #1
Sven32
I work for a BCS dealership and have a customer interested in the BCS739 with the chipper/shredder. He is concerned about the caster on rough ground and if they will hold up constant abuse. I have not sold this attachment so I have no real world insight. Any help?
duly noted, how about constant "use", are these casters, which look awfully small on product videos and literature, able to handle anything but flat land use?
/ BCS CHipper/Shredder #4
I'm going to assume you are talking about the BIO-100?
I had a BIO-100 chipper for a couple years. It was a pain to move around because it wasn't stable on the narrow track width. The narrow hard plastic wheels will sink in soft ground, too. I got around these problems to a small degree by pulling the chipper to where I wanted to go - walking backward and guiding the machine in reverse. Earth Tools offers a wider bar to mount the tires further out from the frame. I don't see it on their website. I've never used one, but assume that it would make the chipper more stable over rough terrain.
Personally, I just don't care for the BIO-100. It doesn't really live up to its claims. I now have a BIO-90, and it's a very good unit, though still unstable when traveling over rough terrain. I plan on putting wider casters on it very soon.
Thanks for the reply. I will pass this along to my potential customer. I am in Canada and they only import one Chipper in for us. Nothing provides a model number like you are referring to above.
I appreciate the insight!
/ BCS CHipper/Shredder #6
I went on BCSAmerica's website, and it looks like Del Morino (or whoever BCS has contracted to build B-100 chippers this week) did make the wheels out further than the Caravaggi BIO-100 I had. It should follow the ground a little better than mine did. Still, the 3" limb capacity is a gross overestimation. It'll chip broomsticks with ease, but put a little bend or a fork in the branch you're chipping, and you'll find out the machine's limitation - you can't get the material to the blade.
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2018 HINO 258A REEFER TRUCK (A63569)
2018 HINO 258A...
2024 DODGE TRUCK BED (A63569)
2024 DODGE TRUCK...
2023 Case IH 110C Tractor W/ Case IH L630 Loader (A64047)
2023 Case IH 110C...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2010 International 4300 2,000 Gallon Water Truck (A64194)
2010 International...
