BCS Acme engine identity trouble
/ BCS Acme engine identity trouble #1
shot_gun
NJ
I have recently aquired a BCS 715. I need a carburator kit for it. We deal with a distributor that sells acme parts but they want a model number and I can't find any. Does any one know where to find it? Your help will be greatly appreciated.
TIA
Chris
/ BCS Acme engine identity trouble #2
I was using that as my guide but on that side of the engine there is only what appears to be a serial number etched into the block. Other ethan that there is nothing. I removed the fuel tank and fan shroud to look there also. I scubed the block and surronding area for any kind of numbers like they say in that list but I haven't found anything. I have the books from the original owner and there is on picture that shoes the engine numbers on the oil fill side of the engine but there is nothing on mine.:confused:
/ BCS Acme engine identity trouble #4
On the thread posted above, write down the answer to all the questions about the gas engine, and call 502-484-3988 and I think Joel can tell you what engine you have and get you the right carb kit. I have a 10hp Acme on a 735, it is ALN330 WB, but I still have to give him the answers to the other questions to get the right part.
/ BCS Acme engine identity trouble #5
Don't know if this will help you out at all, but it may.
Thank you gentlemen. I'll have to give him a call because I'm at a loss.
/ BCS Acme engine identity trouble #8
milkman,
I found all of that BCS info online a while back. The links to the two major sites where I found most of it are in the "BCS parts diagrams... Link to every tractor and implement diagram!!!" post I started a while back. It just takes some digging around.
2022 Belshe WB14 18ft Trailer (A64047)
2022 Belshe WB14...
Friesen 240 Seed Tender (A63116)
Friesen 240 Seed...
2015 Freightliner M2 106 Terex Hi-Ranger TL55 55ft. Insulated Material Handling Bucket Truck (A60460)
2015 Freightliner...
24220 (A56859)
24220 (A56859)
Athey 7-12D Force Feed Loader (A62679)
Athey 7-12D Force...
2022 John Deere Z930R Zero Turn (A63116)
2022 John Deere...
