I bought a BCS 853 2 wheeled tractor this fall and am having some problems with it when snowblowing.
The GX390 engine starts up with no problem and responds properly to the throttle for a while. It also has plenty of power when snow blowing.
However, after snowblowing for about a half hour the engine no longer responds to the throttle when I lower it. It keeps running at a high rpm, but lacks power when snowblowing or under load.
Do you think this is related to ice binding something up or does it sounds like something else?
I appreciate anyones help.
Adding to the excellent comments provided by the TBN members;
The way the cables and linkages are set up on the GX models are an
issue in winter if snow and ice get in there. I always kept my GX340 on
my firewood processor covered for this reason adn the tarp held the heat
in when I heated up with the salamander as it also had a 25 gallon oil tank.
I will say that since your engine is miss behaving when hot the possibility of
ice and melt water and more ice affecting your throttle linkages adds to your
problems as the the GX390 cannot respond to the load as the linkages/cable are
binding because of ice build up and if the garage is not adequately heated you will
still have ice and snow on it.
If the frozen cable is the issue the cable sheath will shift while trying to push the throttle
linkage to increase the engines RPM-you may just not see this happening.
if you can buy a can of cable lubricant or fluid film to spray inside the cable sheath and work the throttle
linkage to get it to move more freely that will help you. WD40 will work in a pinch but fluid film spray
with the nozzle tube extension is the best way to handle this.
Also you need to dry off the snow blower by letting it idle to heat up the engine and throttle linkages
before you pull it in the garage. do not forget that the BCS is going to continue to attract cold air and
moisture to the the engine and everything connected to it.
Me I have gotten way too lazy and use my salamander to warm up the mule and then melt all the snow and ice
off of it and the snow caster when I am done with it before I finally park it and cover it with a tarp if its snowing.
I use a tarp to hold the heat from the salamander long before I even turn the key when I need to clear the
driveways too and it saves on engine wear and heats the transmission oil up long before I start it up.
We still have plenty of winter before us and investing in a small salamander is an investment that pays
huge dividends. I bought my first space heater in 1994 and I wish I had bought one in 1978 when I bought
my home on the mountain as I live at 1140 feet above sea level and it gets very cold and the two car garage that passes for tow car garage was an afterthought by the previous owner of this home as it barely has room to park in it with the sloped roof and.......................................................................................
Make sure its dried off before you put it away next time and lube the cables and linkages change the air filter and clean and oil the foam safety element before you use it again.
Heating your engine for 20-30 minutes at idle before and after up saves you time and engine wear-I had my last truck last me for 15 years before I had to park it as I used a block heater the year round and a salamander to heat it up from the end of September to late April if it was really cold out.
you will use a bit more gas but the BCS will run so much the better for it.
