bcs 852 grinding
   / bcs 852 grinding #1
jomifo
Northeast Ohio
BCS 852
My bcs 852 sometimes grinds when I put it in gear, switch between reverse to forward and reverse and vice-versa, or engage the PTO. It doesn't do this all the time. At first I thought it was the clutch needing adjustment, but I tightened the cable way more that it should be to see if that was the cause, but that did eliminate the grinding, which leads me to believe it is not the clutch adjustment. Any thoughts appreciated. Thanks
   / bcs 852 grinding #2
Sounds like the reverse lever cable needs adjusting. Joel from earthtools has a video on YouTube that shows how to adjust the reverse lever cable.
I don't have a bunch of experience myself with BCS tractors. I just replaced my reverse cable myself after it broke on my 850. I've had a few issues but I just keep trying to plug away at it. Trial and error. Just my 2 cents.
Good luck.
2007 PONTIAC TORRENT (A51247)
2007 PONTIAC...
City of Buckhannon Onan 450 Set Stand By Generator (A52384)
City of Buckhannon...
LOAD OUT INFORMATION (A53084)
LOAD OUT...
2025 SDLANCH SDLE18P UNUSED Mini Excavator (A53117)
2025 SDLANCH...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
John Deere 3025E (A50123)
John Deere 3025E...
