BCS 750 PS with Utility Trailer
   / BCS 750 PS with Utility Trailer #1
ejcrist
Phoenix, AZ
BCS's
I recently bought a BCS 750 PS with the 33" tiller, utility trailer, and chipper/shredder. I familiarized myself with everything and practiced operating and all went well. I've owned a BCS 718 for the last 10 years or so and while the 750's controls are slightly different, it operates essentially the same as the 718. The only thing I wasn't able to do was connect the utility trailer to the tractor hitch while the 33" tiller was attached. As far as I can tell it can't be done. I had to remove the tiller to connect everything up because the curved coupler won't line up with the tiller in the way. So apparently the setup with the trailer and tiller attached together only works for the tillers under 33". Has anyone else noticed this as well? I haven't been able to find any info stating the trailer doesn't work with the 33" tiller so I'm going to call BCS in the morning to verify I'm not doing something wrong. The curved coupler doesn't have a part number on it, and I know there's a small and large coupler, but my receipt has the part number for the larger coupler so I believe I have the right one. If anyone has any suggestions I'm all ears.
Thanks, Gene
   / BCS 750 PS with Utility Trailer #2
Hi! I think may be you can modify your curved coupler for clear the tiller. Good LucK ! Oldmech
Baker BFD80 8,000lbs Diesel Forklift (A51691)
Baker BFD80...
2012 VOLVO ECR305CL EXCAVATOR (A51246)
2012 VOLVO...
2025 Mower King SSEFGC175 (A50123)
2025 Mower King...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
UNUSED HURRICANE 20' X 20' ALL-STEEL CARPORT (A51248)
UNUSED HURRICANE...
2021 Triple Crown U6X14T 14ft T/A Flatbed Trailer (A51694)
2021 Triple Crown...
