BB60 vs EA Rotary cutter
   / BB60 vs EA Rotary cutter #1
tsperry88
Kubota B7610
I have an opportunity to pick up an excellent condition Woods BB60 for $1400. The EA 60" cutter I had planned on buying is more $$. Anybody got knowledge that will push me one way or the other? The Woods is green and my tractor is orange, is one downside😉
   / BB60 vs EA Rotary cutter #2
I bought a used BB72 for $800, but it had output shaft slop and seal out. New bearings and seals fixed it. I think it was ran with out gear lube.
I expected the Woods quick change blade system. It came with standard pins and nuts. That was the only down side for me. I was looking for BB720 in the $2K range when I found this one.
   / BB60 vs EA Rotary cutter #3
I paid $1900 for a Yanmar 72” rotary cutter last spring (YRC720 I think is the model #). It’s almost exactly the same as the BB 72” cutter…..except black. Nice mower and about $500 less than the orange one. Plus I like the way black and green look together😉.
   / BB60 vs EA Rotary cutter #4
Which is heavier, gearbox HP and cutting capability? Those are the three things I look at. Slip joint vs shear bolt is another one.
   / BB60 vs EA Rotary cutter #5
I have an ea 60. I can’t speak for the bb but the ea is a beast. My particular cutter was damaged in shipping and when I contacted ea the parts went out the same day no question asked and they credited me for my time to install the new parts I would recommend ea to anyone who wants a quality American made product
   / BB60 vs EA Rotary cutter #7
A two digit Brush Bull won't be a beast. It's the lightest duty of the series.
The BB is light duty. If you want heavy duty get a Brown 415 but it will be just under $3000 with chain guards and back ordered until Spring
   / BB60 vs EA Rotary cutter #9
The woods is 748 pounds and 65hp gearbox.
The EA is 665 pounds and 45hp gearbox.
You can get parts for a woods just about everywhere. Can the same be said for the EA?
If you are looking at lighter duty cutters it's pointless to mention the handful for $3000 and 1500 pound heavy duty cutters designed to run over 4" stuff. So we won't go there.
   / BB60 vs EA Rotary cutter #10
Also worth asking....what tractor are you running this behind?
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
2022 BARFORD TR8048 MOBILE SCREEN (A51242)
2022 BARFORD...
1999 GENIE S-60 TELESCOPIC MANLIFT (A51242)
1999 GENIE S-60...
2015 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2015 Ford F-150...
2018 DandA 220V Hydraulic Breaker Excavator Attachment (A51691)
2018 DandA 220V...
