Dave M7040
Elite Member
- Joined
- Dec 10, 2012
- Messages
- 2,757
- Location
- Williamstown Ontario Canada
- Tractor
- Kubota M7040 Nuffield 465
So, the fact that we rake hay (very easy load on the tractor) at 1100 to 1200 rpm's for hours and hours at a time with 50, 60 hp tractors will causing wet stacking??
SR
Believe it or not, it is your tractor receiving this treatment.
Myself, I am inclined to listen to the stories from other posters and from serious research papers.
One post comes to mind. The owner was noticing lots of oil laden smoke from his low hours (1,000) tractor with FEL.
He could see the condition getting worse. Most of this tractor's use consisted of moving light material with the FEL.
Quite by chance, he loaned his tractor to a neighbor farmer who used it plowing heavy ground.
When the tractor owner got his machine back after days of hard work he could not believe the improvement that had occurred with his tractor.
I have belonged to this Cat forum which deals with large stationary diesel gensets, often powering island communities, large ships electrical needs, hospital emergency power.
Caterpillar - Home - Online Community
Below is a pargraph from their site:
Underloading Diesel Generator Sets
Generally speaking, standby- and prime-rated diesel generator sets are designed to operate between 50 and 85 percent load, while continuous-rated diesel generator sets optimize between 70 and 100 percent load. Operating diesel generator sets at loads less than 30 percent for extended periods can impact uptime and engine life.
The most prevalent consequence of underloading is exhaust manifold slobber, or wet stacking, which is the black oily liquid that can leak from the exhaust joints when the engine does not reach minimum temperatures and pressures. Visible engine slobber doesn’t necessarily indicate a problem, but it signals possible underloading concerns, low ambient temperatures or jacket water temperatures that are too low. Additionally, long periods of light loading can lead to deposit build-up behind the piston rings or inside the cylinders, which can cause power loss, poor performance, accelerated wear and in extreme cases, cylinder liner polishing.
Dave M7040
