Baumalight MP560 vs FAE DML/Twin
   / Baumalight MP560 vs FAE DML/Twin #1
KenB2920
Almont, Mi
Kubota L5240HSTC
Does anyone have any experience with either of these machines? Any and all info is appreciated as I am about to pull the trigger on one.
I have a baby Kubota L5240 (54 gross hp/ 52 net up and 45 PTO HP). These seem to be the only ones that I found that fit my machine. Seppi smallest is for a 60hp tractor.
I have three rear remotes so I will be able to move the rear door, top link etc.
The baumalight is a lot heavier weighing 2150lbs and the FAE is about 1500lbs. My rear lift capacity is 2900 lbs ish so I think I can handle them.
Thoughts please!!!!
   / Baumalight MP560 vs FAE DML/Twin #2
Did they offer you a demo ? What is the cost difference ? The FAE is a proven name but my son bought a baumalite stump grinder for his 35 hp JD tractor and it is well made and works awesome . The Fae may have better trade in value . It also has a cam clutch instead of shear pins . Very good .
No demo and nothing even remotely close that I can find in my area to check one out. (or either one for that matter). Is the baumalight shear pin? I have to call the dealer on the baumalight but I think it's about 5+ grand more.
I am trying hard to search and look but being I have such a small tractor and this appears to be a Niche market it's hard to find.
   / Baumalight MP560 vs FAE DML/Twin #4
I don’t know if it is a shear pin . What is the cost of the teeth ? The stump grinder teeth were inexpensive .
The teeth are $58 each which is pricey. The Rep told me that is retail and anytime you call will get 15-20% off. I asked what if I order an extra set now and he said he could do 30% off. Knowing teeth will be needed at some point I will just order a set. So $40 each (This is for the FAE, I don't know the cost of teeth for baumalight.). However, I think the baumalight has twice as many teeth to replace.
Just combing over some of my old threads. In case anyone cares, I went with the FAE and it's a sweet addition
This is already after being used for days.
   / Baumalight MP560 vs FAE DML/Twin #7
Kenb2920, when you are cutting brush do you run tractor in forward motion ? Does the mulcher cut well in that manner ? Do you have to go over it a second time for finer mulch ? How thick is the brush you cut 1" to 3" ? I hope to upgrade to a 60 to 68 pto HP tractor with a seppi miniforst 175. I hope to use the bucket on the loader to push down the brush and let the mulcher do its job. How do you use your equipment ?
I back into majority of the brush ... if the material needs a finer finish, I will then drive forward over it. With that said, i bring in the top link when driveway moving backward and I extend the top link when driving forward....
UNUSED X-STAR 750 GALLON FUEL TANK (A51247)
UNUSED X-STAR 750...
2001 Chevrolet Suburban SUV (A51694)
2001 Chevrolet...
LG TRUE BALANCE WASHER & DRYER (A51248)
LG TRUE BALANCE...
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
9202 (A50322)
9202 (A50322)
