Batwing project
/ Batwing project #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
/ Batwing project #2
It doesn't match your tractor? I'll bet there was lots of corners to put paint in and what kind of paint did you decide on? looks good
Jim
/ Batwing project
Jim
Yep.. I know.. It's a JD 1517 batwing.. and I drive mostly Ford / NH.. but I couldn't pass upt he deal.. Batwings around here go inthe 5000-6000$ used range.. this one was 2000$.. tires 20% .. but hold air.. for now... lots of degreasing.. and some rust pitting.. but no rust thru. New blades.
I simply couldn't pass it up. It cuts great. I did a little minor welding on it.. fixed the brush guards, and degresed and pressure washed it for a week.
It should serve me well.
After priming, I did alot of the corner, and 'hidden' spot painting.. then I blew the main coat. Turned out good.
Soundguy
/ Batwing project
ToddW said:
If it cuts as well as it looks you've got it made. Good job!
It cuts great. The flex wings really follow the terain much better than my 10' fixed mower, and i can cut as close as 2" from the ground if i want.
To the other poster.. mr jimi... I forgot to say that I used the TSC BPS paints, and a valspar rust control ( etching? ) primer, and a valspar hardner.
Soundguy
/ Batwing project #7
As always, you did a great job Chris. Looks good!!!
213086 (A64276)
213086 (A64276)
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
3143 (A63117)
3143 (A63117)
250 Gallon Diesel Fuel Tank w/ Pump (A64047)
250 Gallon Diesel...
2004 Rogers Detach Lowboy, 28' Well, Tandem Axel (A62679)
2004 Rogers Detach...
2014 Freightliner Bucket Truck (A63689)
2014 Freightliner...
