Batwing mower pillow block
   / Batwing mower pillow block #1
clwhite
Just started using a used Bush Hog 2615L 15' batwing. Surely saves time from my 5' rotary. Mine came with a pillow block on the driveline between the PTO and the divider gearbox, but I think it's optional. When I turn in the field even 20 degrees, I can feel and hear increased vibration. What's the advantage of the pillow block? Would I reduce vibration (and presumably wear and tear) by removing it and going with a straight shaft from PTO to divider gearbox? Thanks guys.
   / Batwing mower pillow block #2
Sounds like something's worn out on it. I'd guess it would be better to find out what's loose and replace that than to change it to a longer shaft.
   / Batwing mower pillow block #3
I agree with jake98 on this one. I don't think running a straight shaft will handle the turning angles that you are going to experience with the batwing. I have a 20' batwing. It is old and worn as well. When I know that I will be going into a tight turn, I disengage the pto. Given that you just picked up a used one, though it might be in good condition, I am willing to bet that you have more than a few bushings, connectors, couplings, and bolts that could use replacement or a good tightening at the least!
Hawk
   / Batwing mower pillow block #4
You have alot of worn driveline parts that need quick fixing as the little bugger is binding due to the worn bearings and bushings and the turns are making it worse by increasing the binding due to the excess clearances from wear and tear.
Thanks Jake and Hawk. I've gone over almost everything, and it's pretty tight. A few plugged zerks, but that's normal.
2010 CHEVROLET SILVERADO 1500 (A53843)
2010 CHEVROLET...
2014 CATERPILLAR 826G LANDFILL COMPACTOR (A51406)
2014 CATERPILLAR...
2017 JEEP CHEROKEE (A53843)
2017 JEEP CHEROKEE...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A53843)
2011 NORAM POWER...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A52706)
2018 GENIE GTH-636...
2009 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2009 DRAGON...
