Batwing/BW12, sticky hinges on wings
   / Batwing/BW12, sticky hinges on wings #11
Yes drill the hole just smaller than the widest part of the V tip then hold the tip in the hole straight and snug and pump yer grease right in. I'm new to this computer thing and haven't figured how to post pics yet. However if you go on Amazon and find their Rexbeti grease gun it comes with the V tip as accessorie, the gun and all is only 21.99. You don't need to pull the rod out before drilling either you can tell by feel when your thru the outer hinge, it doesn't take long at all and works very well. I do this anytime I'm needing a zert fitting but have no room for it. B
As you remove the old round stock can you slide the new in right behind it from the other end? So everything stays put. The other is put cylinder stops on the wings so they can't raise up quite all the way. And lower when using.
The stops can be removed overnight and off season..
Maybe. It honestly looks like quite an operation to get that pin out, there's no "square" way to hit it, one side (front) is in a bit of a well, and the back side (which is where you have to drive it out) appears I'd need to pull the wheels off. It's doable, but I don't think I can knock one out and follow it with another one, not the way it's set up (because one end has deck in the way). Not a great setup.
However, one thing I hadn't thought about (thank you!) was putting some stops on the wings for mowing. I don't need the wings totally vertical to get through the areas I need to go with it, even 50-60 degrees would be enough. And I have a ton of stops, so I'm going to try that for sure, it's really only if you let the wings get to 90 that they "stick", the moment you pull them down beyond vertical they start to fall by themselves. So, for sure, I'm gonna give that a go the next time I mow and see if that solves the problem for me, but I suspect it will (coupled with the newly lubricated hinge, of course). I think the easiest of all these ideas is probably to just drill a few holes in the hinge and use some kind of needle type injector to shoot some grease in, I suspect that'll work for me when I get up the gumption to drill a dozen holes in there. I'd love it if I could find some kind of zerk to go in there, but, honestly, it's probably overkill, just a hole in the middle where I push grease in will probably be fine.
Thanks for all the suggestions guys. I have to go out and do a little more oiling today, it's hot as he** here and I left it sitting in the sun, so it should soak oil up nicely now down those hinges.
The tip all the way on the right is what we're talking about?
https://www.amazon.com/REXBETI-Extended-Reinforced-Coupler-Included/dp/B07HMYL6T7
   / Batwing/BW12, sticky hinges on wings #14
Yes that's it. The hole has only got to be big enough to just get the angled tip started in, I'm thinking maybe 1/16 or so. It will work like magic B
   / Batwing/BW12, sticky hinges on wings #15
Maybe I missed something here but you not only drill a hole in the end of the rod for the grease fitting but you have drill into the rod the length the grease will be coming out the side of it and cross drill holes to allow the grease to come out which I think means you will have to pull the rods out and have a way to drill a hole in 1/2 rod. Only way I believe you would be able to that is with rod in a lathe and drill be being feed into the rod. Of course the drill bit must be long enough.
Hard to believe there is no way to lube the hinge good enough that it will work fine. Can you replace the hinges with a better style of hinge? Can you not install double action acting cylinders?
   / Batwing/BW12, sticky hinges on wings #16
To me there's no reason that you shouldn't have zerks on the hinges of mowers like that. Zerks could be installed in a position to where they're not going to be knocked around that much and I think it would work great it just be time-consuming to drill that many jerks in.
If we're taking votes, I agree with you. Especially since that mower has zerks everywhere. I kid you not, there are 2 zerks on EACH altitude adjustment for the wings. One on each side of it. That's an adjustment that most owners will make once and never again unless you change tractors (drawbar height). 2 zerks for something that will probably never move more than once. And 0 zerks on something that moves constantly when the mower is in use. Because those hinges aren't just up and down, they move when the contour of the ground changes. Basically, if you watch the mower, unless it's DEAD flat land, those hinges/joints are in motion constantly, and with quite a bit of force on them too. They are also really "open" joints (because it's basically a piano hinge) with LOTS of places for water to get in. Nahh, no zerks in that though, even though, outside of the wheels and spindles, there's probably nothing on the mower that gets more "action" than those hinges. Brilliant I tell you, brilliant. And, not isolated to just me, I've read a few threads with "sized hinges", including one where the guy had to take a demo saw to the mower and basically start over!
Anyway, engineering snafu aside, I wanted to report back. I put a 1" stroke control on each wing. That's the end of that problem. Now the deck maxes out around 75 degrees or so (instead of 90 to the middle deck) but the deck goes up and down like a dream. The weight pulls it down easily once it's pulled a bit in that direction. Or course, I can't lock the deck up with them in place (but I never need to, this thing never sees the road, just my farm) and, it's a bit wider (probably 8' total width instead of the ~6ft it is with both wings fully folded). Still a heck of a lot less than the 12 it is all the way down, and "small enough" for the places I need to get it into where the 12' is too much to go through (gates, between trees, etc).
I'm probably still gonna drill it, but I'm going to wait until the winter, this is good enough and it's too hot out there to be fussing with that thing anymore. I'll keep dripping oil in after a mow and working it back and forth; but it seems it's 90% fixed right now. Might be 100% fixed if I mow enough with it like this and that oil I'm dripping on it works it way further into the joint.
Really stupid design. And that's disappointing because everything else on this mower is just so well thought out. It's an obvious weak point though, and one that owners should be aware of. I suspect if you shoot oil in there from day 1, or, if you drill it when you get it, you'll never have this problem. It's stuff like that that makes you wonder, how on earth did nobody catch this when they were designing in? I know, we'll run a 4 ft hinge that's open to the elements out of mild steel with 10 joints on each side. Grease fittings? Pfft.. Who needs that??
   / Batwing/BW12, sticky hinges on wings #18
And I think all bat wings are made that same way.
Begs the question.. Why? I mean, do they know something we don't? Greasing that hinge gets too much dirt in there and they seize prematurely? IDK, I'm just contemplating, why wouldn't they make that a grease joint. Honestly, the abuse that joint takes, the water, chaff, dirt, etc.. If I were building this thing, I might opt to put sealed bearings (2) in each of the joint areas so that it's not riding metal on metal and stays clean/dry inside the actual joint itself. I'm sure my new greasing system will work fine, but it's a mess and it certainly allows for lots of crap to make its way into this joint over time.
Random question, I've looked in the manual and I can't find the max wing lift height/angle when the PTO is engaged. Anyone happen to know for the BW12 if it can run with the wings "up"? I've read it's hard on the ujoints and driveline, but I've never actually seen that said in the manual (don't do it, or only do it to this angle, or only do it for X amount of time).
   / Batwing/BW12, sticky hinges on wings #20
They are after a share of the mower/shredder market in that size like the rest of the builders of these things.
They are simple to build with plate steel right angle gearboxes and three shaft gearboxes that can be easily used with longer propeller shafts to allow them to make a folding rotary crop shredder mower
Like the rest of them they are not ment to be used with them raised as there is a maximum angle of deviation from horizontal that they can be used with which is very small as they are used for clearing many vine crops after harvest or in potato's to knock down the potato vines and most of the these universal joints are also used for heavy truck drivelines.
The maximum raised angle can be reached only with the tractor PTO turned off as they can tolerate that amount of angle without being engaged simply due to the amount of extension and retraction created by the hydraulic cylinders raising and lowering the wings with the propeller shafts on the wings of the rotary crop shredder mower moving in unison with the mower wings if my memory of the design is correct.
The operating angle of the propeller shafts is limited to the maximum angle that the spiders/crosses/universal joints can tolerate during operation and I believe it is no more than 10 degrees above horizontal.
The 3 section folding flail crop shredders have the same limitations in movement as a folding rotary crop shredder.
The best universal joint manufactured is the Rzeppa Universal Joint Used on many brands of mining machinery which looks nothing at all like the universal joints on power take off shafts we use today. They are expensive to purchase but they capable of more usable angles of power transmission to the end use due to the design.
They have to be greased every time the machine is used and the grease must be purged through the end bells or drain holes to force out the old heat damaged grease.
This brand of universal joint has been manufactured for a very long time being 50 plus years and they are very reliable.
The smallest RZeppa universal joints are used on small all wheel and 4 wheel drive automobiles from what I remember and require a dust and dirt boot that keeps the water, fine dirt and salt out of them.
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
1992 DFI PULL SPREADER (A57192)
1992 DFI PULL...
Hyster H80FT 8,000LB Forklift (A56857)
Hyster H80FT...
2019 PJ TRAILER 32FT GOOSENECK (A58214)
2019 PJ TRAILER...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
