Battery
   / Battery #21
I have a drop cord at each tractor to power a small battery conditioner on all of my farm vehicles. I seldom have any issue with a battery and they crank over fast for good starts when cold.
Agree with this, regardless of battery brand. :thumbsup: I try to keep a small, "smart" battery maintainer plugged into each of my tractors when not in use for more than a few days. Also, 24/7 on the small "motocross-style" battery of and electric-start standby generator. With today's solid-state circuitry, they're pretty fail-safe.
For the last five years, I've been using the so-called "deluxe" model from HF. Never a slow start or a failure of a charger or battery. 12 Volt Deluxe Battery Maintainer and Float Charger Before that I used the more basic model with only the alligator-style clamps. They're fine as well, but being able to permanently mount a connector lead to the battery terminals and then just plug in is real convenient.
   / Battery
well thanks guys for the tips on batteries and where to get them, Now for my next question another engineer needs his *** kicked! what is the best way to get the battery out of my L3940 bracket right in the middle for side grill and head lights. Nice job Kubota!!
   / Battery
i realize that, loaded question? just asking what others have used in there Tractor, some batteries i have found don't like the rough ride! I did not ask where to buy a battery i know where they are sold, just asked what others have had good luck with COM DOWN DIGGIN
   / Battery #24
I don't specifically know this model but I do know the dread I felt when I looked into removing the battery on my L4300. It looked like I would have to dismantle the tractor and I started blaming Kubota.
Well, I looked at an exploded parts list form Messick's first and then searched the Internet and YouTube for solutions from others to this problem. Turns out the battery removal was way easier than expected by removing a small bracket. Kubota had already thought it through and solved the problem. What I thought was a two hour job was a 15 minute one mostly because I had to go back for the beer.
Bottom line, keep searching on line for the actual experiences of other and see if there isn't an easier way already out there. Can't hurt.
   / Battery #25
I get my battery from western auto, they had the same size battery, an it was a reverse polarity on the battery.
   / Battery #26
I had no idea that Western Auto was still round.
They have been gone for my area for 40+ years.
   / Battery
so what did you take off the bracket for bottom guard shield and headlight bracket?
   / Battery #28
Assuming you mean on my L4300, I can't remember exactly but I think it was the bracket that runs from the top to the bottom behind the grille. I may have only just loosened things up to gain a little more access and not removed anything. You have to look at the installation, look at the parts picture and then search the internet for others that did it. We have different models but the thinking is the same. Hope this helps.
EDIT--Am remembering more. I don't think it was the bracket, I think it was part of the grill or grill shell. Again, mine is different from yours.
   / Battery #29
I have never had an issue trickle charging batteries a couple of times over winter. In fact, I'm not so sure that charging them continuously, no matter the gentle charge, won't do more harm than good. But that's just a thought. If you have equipment that will kill a battery over time, it's a different matter.
2016 Hyundai Sonata (A56859)
2016 Hyundai...
2026 tilt trailer (A56859)
2026 tilt trailer...
2010 MULTIQUIP 25KW GENERATOR (A58214)
2010 MULTIQUIP...
2019 Ford F-550 4x4 Crew Cab Utility Flatbed Truck (A55973)
2019 Ford F-550...
SKID STEER ATTACHMENT RAKE (A58214)
SKID STEER...
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
