battery
/ battery #1
hunterjo
muskegon mi.
john deere saber
does a older Kubota tl 420 have a positive ground electrical system or a negative ground system. the model is b20bh
/ battery #2
Isn't the TL420 just the loader? Would it have any electrical at all?
Try this page: Kubota B20 | Messick's
Being 1990-1998 and 12 volt, I'd say almost certainly negative ground if it is a U.S. marketed tractor.
You can have an electrical systems parts diagram emailed to you from the Messick's site.
/ battery #3
Positive ground was common up until the 1950's when automobiles and farm equipment changed from 6 volt to 12 volt electrical systems. There were some holdouts in the automotive world, including a few European and a couple of Japanese makes, but by the late 1960's pretty much everything had 12 volt negative systems. Since Kubota started selling in the US in the '70's, I don't think anything they officially sold here was not 12 volt negative. Can't say about a "grey market", illicit import, but unless someone has totally boogered up the electrical system (that's a technical term :laughing:), it's a virtual certainly your B20 from the 1990's has a negative ground.
/ battery
yes I was wrong the model is a b20 bh. also I found out it is a negative ground system. that is why it had multiple electrical problems I am working then out as I speak. thanks to everyone who got back with me.
hunterjo
2022 Takeuchi TL12R2 (A64126)
2022 Takeuchi...
2016 Hyundia 53' Dry Van Trailer (A62613)
2016 Hyundia 53'...
1999 Sterling Dump Truck (A66285)
1999 Sterling Dump...
2020 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61573)
2020 Mack Anthem...
UNUSED SDLANCH HYD DUMPER (A64280)
UNUSED SDLANCH HYD...
2005 Freightliner M2 106 Ambulance (A61573)
2005 Freightliner...
