Battery
/ Battery #21
Gel batteries (like Optima) and AGM batteries in a class of valve-regulated lead-acid (VRLA) batteries. They are sealed and can be used in any orientation, won't spill acid, and tend to tolerate vibration better. The main advantage of VRLA for us tractor types is their very low (compared to normal "flooded" batteries) self discharge rate; they won't go dead if they sit uncharged for weeks or months (well, they do but very slowly). On the minus side, they are less tolerant of overcharging. With spiral-wrapped gel batteries, like Optima, the cells are cylinders and this limits battery size and shape to an extent (width is 150% of the depth). AGM batteries use rectangular cells so they can be just about any rectangular shape. VRLAs cost about twice as much a flooded batteries but don't last about as long, all things being equal. It's easier to kill a flooded battery by undercharging or contamination and easier to kill a VRLA by overcharging. My 2006 DK45S still has the original AGM battery, I think (not sure because I bought it used). All this notwithstanding, there is no value in putting too much battery in your tractor unless you plan to run the radio for long periods with the engine off. If a healthy battery can't start your Kioti, almost immediately, something in the tractor needs to be fixed. The exception would be a very cold climate. But even there, a block heater and battery heater are a better strategy than a super big battery. The super big battery can cause excess stress and wear of unlubricated surfaces until the oil flows; but the block heater helps the oil flow quickly and the battery heater will yield the full cranking amps. on a related topic, a good synthetic motor oil will flow at much lower temperatures than conventional oil.
Probably why most off-road racers use Optimas in their trucks etc.
/ Battery #22
Well said!!! With all my experience with dual 6 volt systems in series I am against using the system.
2 6 volt batterys connected in series means,
12 volts but Does NOT double the amperage. Amperage stays the same. Two six volt batterys with 300 CCA will still have 300cca. More connections to fail.
I don't blame you for wanting a better battery for all means but you could have 1500 CCA and the starter will only handle so many amps at a time.
Check connections
Clean connections
Check cables
Paint connections after done cleaning to insulate them
With cold weather you need to worry about more than a battery as previously stated. Deep cycle batterys can take more abuse than a normal battery just as optima battery's are stronger than your regular battery.
One more thing, before starting your tractor you can plug in a battery charger to "top off" the battery before you start it maybe 2 hours to 4 hours before. This will keep it ready and will keep it cycled and warm makes a big difference. Best time to plug in a block heater and battery tender or charger.
/ Battery #23
im confused why you need more cranking power. Mine fires up in 2-3 seconds after turning key. The preheat and plug in heaters do wonders.
/ Battery
diesel lover - I heard the statement on 2x6 volts in series. Thank you. That is the part I hadn't heard before.
I need to get an Optima for the Heep in Spring so I might as well get two and put one in the tractor. I could put the one out of the Heep in the boat for a starting battery and get another Optima for the house battery. The boat has two cheapie CTC batteries in it right now.
Batteries don't like cold temperatures. The more CCAs the better in my eyes. By cold temps I am talking -30*F . I tried to start her yesterday, the temp was -30F. After the glow plugs got cycled twice she cranked slowly and wouldn't fire. I am guessing it is the battery, OR it could be that I didn't give the block heater enough time to warm things up. I'll go outside tomorrow (Thursday) and trouble shoot it. I will be putting a battery charger on it for a couple of hours.
/ Battery #25
At minus 30 you definitely would be best off with a full synthetic motor oil. Your battery may be straining to turn over your engine but your engine is probably trying to tell you to go back inside and don't spin a bearing due to lack of/no lubrication to the engine parts. More CCAs may just end up spinning your motor into a destroyed state. Unless there is an absolute need to start in arctic temps, why risk serious damage to your machine? I wouldn't.
And Interstate are some of the best made batteries out there, I know first hand because I sold them from my foreign auto shop for many years, and use them in my tractor, boat, cars, trucks, etc.
Check with your selling dealer as to what the warranty is. I have 9 in use as we speak.
/ Battery #26
I have an Interstate 12Volt battery that came with my Kioti (2012).
(A) How long is this battery supposed to last. Answer:Much of this depends on the amount of use, maintenance (keep the electrolyte levels full) and the quality of the battery. The longest I have had a battery last is 6 years in my truck and that I believe was because it sat unused for 8 months( some of which had a battery maintainer on it) at a time for the first 2 years so no degradation of the battery happened. In my experience, after 4-5 years on any battery, you are living on borrowed time on automobiles simply because they have a high demand for power with all of the equipment on them. Diesel tractors that don't have a lot of extra lights have very little draw and 6 years or more is quite common for a battery to last if maintained. My 2009 Kubota has original lead acid battery in it and going strong.
Question is; (B) wouldn't 2 of 6 volt batteries wired in series do a better job? The answer is yes and no, If you got two 6 volts with the same CCA of the one 12 volt and put them in series you would get more amps to draw on for longer period of time before draining the battery Older tractors of larger engine/higher compression needed those amps to crank with but not the CUT's of today. One 12 volt supplies plenty of amps to do the job so there is no need for 2 batteries. Besides that, there is really no place designed to put an extra battery on our tractors today. You likely don't have the amp capacity on the alternator to charge two large batteries without damage to the alternator. MY LS P7010 (70HP) cranks quite well on one 12v battery even in colder temps. This could also be because of todays starters with super magnets in the stator produce more cranking power with less amps. Using the glow plugs even after engine starts sometimes help them to rev up quicker rather than stutter and smoke excessively. I noticed the NH of my brother in laws didn't want to rev up even though it started with one cycle of the glow plugs. I hit the switch to energize the GP's and it came to life then.
I for sure know that you don't want to kick the voltage up to 24 volts because while it may spin the heck out of the starter, you will burn it up quickly.
Other advice on using a block heater, battery heater blanket etc is also good advice, but the main thing is that if your vehicles aren't cranking easily when turning over, fix the problem. IT's not the battery. All my engines crank within in a second of 2 at most when properly using glow plugs. If your diesel has to grind and grind on the starter to crank, there is other problems than battery.
PS: on an old AC WD45 we had once, it was notorious for hard to start. It used 2 ea large 6 volt batteries and still turned too slow to start about half the time. Dad replaced on of the 6 volts with an 8 volt so it used 14 v and it cranked much better. I don't even know if you can find an 8 volt battery today but they were pretty common in the early late 50's-60s. The 14 volts didn't even need to put a resistor in the light circuit.
/ Battery
I think most of my problem is that the block heater was only on for about a half an hour and the temp was -30F. I'm going out in a few minutes and will put the battery charger on it. Tomorrow, in the morning I will fire up the block heater and warm it up good for a couple of hours before I try starting it. (I get up at 7, but I don't bother to get around to doing anything until noon.)
/ Battery #28
Here in VA we normally don't get super cold temps, but this January has been different. Several consecutive days of subfreezing temps. As my tractor is only covered by a tarp and kept under the back porch (no garage), I remove the battery and bring it inside for Jan until early March. Probably unecessary, but makes me feel better!
/ Battery #29
If we are getting a snow storm and cold temperatures I always plug in the block heater the night before and in the morning it always starts like summertime after I activate the glow plugs.
/ Battery #30
I have a 1997 f150 with a freeze plug installed block heater. I also have a laser temperature gun that goes from -75°F to 980°. Has to be plugged in for at least 3 hours to make a difference on the coolant temperature measured at the thermostat and upper/lower radiator hoses. 4 or 5 hours works better. It was -14° F here a few weeks ago. I needed to make sure my truck would start so I could get to the truck shop I work at. I knew it would start when it was that cold as I had to start it at work without the block heater. It was the sounds, hard cranking etc that I didn't like. If I plugged it in for at least 4 hours than it would make a huge difference.
If I knew I had to start it soon after a nights sleep I would come straight home, shut the truck off, plug in the block heater, go to bed and the truck would whip right over sometimes like it was 50°F outside. I do not know if it makes a difference to plug it in when the coolant is cold or warm but it seems like mine maintains the coolant temperature well.
One more thing, you could buy a timer for christmas lights etc from a home improvement store. They are usually rated for 1800 watts is your good to go. Then you could set the time you want the timer to turn on for 5 hours before you have to plow the driveway.
/ Battery #31
I'd be real careful that you're not charging a frozen battery at those extreme temps. I'd connect the charger to teh battery and then plug in the charger away from the battery area just in case.
You might want to consider getting a battery blanket which wraps around the batter and plugs in when it's super cold out. I have one on my generator's battery and it works well.
Bet the battery wears a smile too.
Starting with warm coolant is easier to maintain the warm temp than starting from a cold block and trying to warm everything up.
Yeah, that's a good way to do it, and save on electric too.
/ Battery
I have a 1997 f150 with a freeze plug installed block heater. I also have a laser temperature gun that goes from -75ーF to 980ー. Has to be plugged in for at least 3 hours to make a difference on the coolant temperature measured at the thermostat and upper/lower radiator hoses. 4 or 5 hours works better. It was -14ー F here a few weeks ago. I needed to make sure my truck would start so I could get to the truck shop I work at. I knew it would start when it was that cold as I had to start it at work without the block heater. It was the sounds, hard cranking etc that I didn't like. If I plugged it in for at least 4 hours than it would make a huge difference.
If I knew I had to start it soon after a nights sleep I would come straight home, shut the truck off, plug in the block heater, go to bed and the truck would whip right over sometimes like it was 50ーF outside. I do not know if it makes a difference to plug it in when the coolant is cold or warm but it seems like mine maintains the coolant temperature well.
I have 2 remote electric thingys on different frequencies that I plug the Heep and the tractor into. From the house I click on the key fob thingy and either the Heep or the tractor block heaters activate depending on which one I want. I put a 3 way power tap after the remote and hook up led lights to it and hang that outside either garage as an indicator of whether the block heater is on or not.
I just got back from town and the battery looks like it is all charged up (wasn't that low to start with). IF it snows overnite, then I will fire up the block heater when I get up (7) and try starting it at noon.
/ Battery
I'd be real careful that you're not charging a frozen battery at those extreme temps. I'd connect the charger to the battery and then plug in the charger away from the battery area just in case.
I pulled the caps and looked in the cells, not frozen. But I did plug the charger in AFTER I hooked the battery up anyway. That is just the way I do it anyway. I know what exploding batteries look like, I did one years ago that my boss was too cheap to replace (It was toast and he was too cheap to replace it), it was scrap after I got done with it.
/ Battery
Had my sweetie (Kioti) running today for about an hour. I charged up the battery yesterday and turned the block heater on at 7 this morning. I went out at 11:30 and she started right up after two cycles of the glow plugs. I guess it was my bad for only letting the block heater run for about a half an hour and then trying to start it in -30*F temps.
Thanks to everybody that threw suggestions and cautions at me.
/ Battery #35
Not a problem!! I'm trying to spread the word to more people fast this time of year. I'm getting up set with these people that "know" block heaters only need an hour max to warm up. After that it could catch on fire or something .... WRONG. So wrong. I have a laser temperature gun and after doing my own research with my own block heater here were the results at 20 degs : freeze plug heater plugged in and in under 5 minutes time out side surface temperature of freeze plug is 100 degs F!! Check again maybe 20 minutes later and surrounding areas from freeze plug are 40 degs and freeze plug is 50 degs. Pretty amazing. Upper and lower radiator hoses are warming up. 4 to 5 hours is perfect with mine. The heat circulates around the engine. Its one of the best inventions in 100 years when it comes to cold weather!
/ Battery #36
Nothing like doing some actual real world testing:thumbsup:
/ Battery #37
Could not agree more, the truck shop I work at full time our trucks have idle timers so they won't run more than 5 minutes on their own. They will shut off with out increasing the idle using the cruise controls. We have 250 trucks parked at one time at our 40 acre facility. When the bad weather hit we had close to 300+/- parked due to roads closing down and red alerts with officers giving tickets for driving in these conditions. The long and short of it is that if the trucks block heater was plugged in, it was likely to start. Over 90% of the trucks that didn't get plugged in would not start. A cold start is not only about the battery's, fuel additives and block heaters but it also has a lot to do with block heaters. My advice here is that every little bit helps. There is a huge difference between almost starting and barely starting. If an engine almost starts in the cold your cursing and throwing wrenches around!! If an engine barely starts you feel a chance to get things accomplished.
We have had so many trucks not start this winter. Its been -14° F very tough to work with trucks that are shut off and not plugged in. These trucks do not have trickle chargers hooked up so dead batterys are a large issue. We run 15w40 engine oil as well. Corporate has finally decided these trucks if they are 2010 and newer they need to stay running. This was not until all these "no start" situations. In the shutoff policy in order to save fuel they have bought several battery's at 100$ a piece (trucks have 3 or 4) and several wrecker calls easily 1500$. We get paid to get trucks running but what a pain!! Its not easy when the battery's are discharged and they were not plugged in. Its easier for us to take our pay loader and DRAG them across the ice. They slide as easy as a hockey puck with how much ice we have this year. The brakes are usually locked up because the air tanks don't have enough air pressure built up to force the brakes to release.
All I can say here is after years experience is keep it simple, come up with other plans this year in cause you have equipment down and can use other equipment to help, plan ahead, keep chains/ thick tow straps on hand as they are worth their weight in extremely tight situations and try to be safe!! I do hope all of you have helped a neighbor in time of need with this weather. They will remember that and repay you when you need it
2022 THOMPSON PUMP 6X6S1 PORTABLE PUMP (A59823)
2022 THOMPSON PUMP...
2011 DOOSAN G40 GENERATOR (A55745)
2011 DOOSAN G40...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
2018 Freightliner M2 106 Cab and Chassis Truck (A59230)
2018 Freightliner...
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
(APPROX. 25) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 25) 4' X...
