Battery Time
   / Battery Time #1
BrandonEvans
Pittsburgh, Pa
John Deere 4200
Hello All:
Went out today to start moving around 20 yards of malch and being this was the first time starting in 40 degree weather the old battery couldn't take it.
Without opening a hug can of worms.....what is the best/easiest/cheapest replacement without paying for a JD branded OEM.
I would like to use the factory mounting brackets and not fabricate some crazy contraption to hold the battery.
Thanks in advance,
Brandon
4200, 420FEL, 60MMM, PHD, BH
   / Battery Time #2
Have you tried charging your current battery?
   / Battery Time #3
Check your local Wal-mart, they carry a good selection of batteries and their prices would be lower than most. My buddy found a replacement battery for his NH 1520 there that was an exact fit and it was something like $40 exchange.
   / Battery Time #4
The best solution is a bettery maintainer, if your battery isn't already shot.
Regular bartteries for automotive applications have two shortcomings: They aren't made for the rough service of a vehicle without a suspension. They'll rattle apart if you have a lot of rough ground.
The other is the typical tractor useage includes perios of disuse that really wears on them.
To me, as I keep saying, its hard to beat $60 more for an Optima. That sounds high, but not at the rate I value my time, especially if I would have to replace a radiator or two and do frame repairs...
   / Battery Time #5
I bought a direct replacement at TSC (under $40 I think) that uses the same tie-down as the original battery. I believe it is a 22N. I've had it in almost a year with no corrosion problems at all.
Hope this helps.
STORAGE FEES (A52577)
2018 Gatormade 20+5 Gooseneck Trailer (A52748)
2018 Gatormade...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2017 Ford F-150...
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
