Battery terminal corrosion on 4400
   / Battery terminal corrosion on 4400 #11
more than likely it's one of 2 things eather the vibration of the tractor has cracked the case on the battery (can be found by spraying some cleaner/checker from wally world) or possibly just nature of a non-sealed battery that emmits natural gassing as it discharges/charges due to storage etc.
if the battery's not cracked all you need to do is put a coating of grease to prevent the gasses from corroding the terminals as for the other corrosion indicators i'd say you've got a busted battery
2005 Toyota Highlander SUV (A55853)
2005 Toyota...
2008 CATERPILLAR D6N HIGH TRACK CRAWLER DOZER (A52707)
2008 CATERPILLAR...
2017 Ford Explorer (A56859)
2017 Ford Explorer...
JCT 48" HYD TRENCHER (A52706)
JCT 48" HYD...
2019 Ford F-250 Super Duty Crew Cab (A55852)
2019 Ford F-250...
2014 Toro Workman HD Utility Cart (A55851)
2014 Toro Workman...
