Battery Tender
/ Battery Tender #11
A real battery tender won't do that. I have one on my 25KW generator that has been on continuously for 7 years and the battery is still fine.
/ Battery Tender #12
The quality and function of the charging device will determine if it maintains or even damages the battery it is connected to. A maintainer/tender/trickle charger is a low current charger, designed for long term use.
/ Battery Tender #13
There's a make of battery tender made by a company called Battery Tender. That's what I've been using for quite some time on generators. Tried almost everything on my portable generator to keep its battery up. Nothing worked until I bought a Battery Tender. Now I have one of the all weather ones connected to my 12.5 kw diesel generator. Tried a solar one there, but it wouldn't do. Have a solar battery tender on the battery for my electric fence and have 2 solar ones on the battery to our gate.
Battery tenders sense the battery voltage and don't put juice in unless it's needed.
Don't use an indoor (cheaper) one outdoors. Had an indoor one initially on my diesel generator. Even though it was protected by a cover where it was plugged in, it failed. The outdoor one (more expensive) now on the generator is quite old. Old electronics keep going though unless they get fried by something.
Ralph
/ Battery Tender #14
Are the battery tenders you all are speaking of made in Florida? The reason I ask is if so they are used on E-ONE fire trucks as standard equipment. If these are the same they do work great.
/ Battery Tender #15
Yes, DeLand, FL
2013 Dodge Charger Sedan (A55973)
2013 Dodge Charger...
2020 Sellick S80 (A60462)
2020 Sellick S80...
CFG NT18K (A60463)
CFG NT18K (A60463)
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
EXCAVATOR COUPLER (A60736)
EXCAVATOR COUPLER...
2015 JLG Skytrack 8042 (A60462)
2015 JLG Skytrack...
