Buying Advice battery spec for jimna tractors
   / battery spec for jimna tractors #1
garyvfr1
Nr Banbury
jimna 354 4wd
what type / size of battery do I need for my jimna df354 tractor put on a new battery from halfords 12v 95ah 830amp will initially crank it over but when i try to restart there is no power to it sounds just like a flat battery noise solenoid clicking thinking of replacing with halfords top spec battery 85ah 800amp hsb110 what does anyone think
Q: could there be an underlying problem with the starter / solenoid if so can i repair
   / battery spec for jimna tractors #2
The highest CCA and highest amp hour capacity that will squeeze into the battery box. Run a ground cable direct to a starter mounting bolt if the factory path is through a bolted sheet metal path.
   / battery spec for jimna tractors #3
These tractors are know for having low voltage at the starter solenoid. The is an easy fix by adding a relay. (Do a search you will see many threads on how to do it). So unless you have had your battery tested and it is proven bad I suggest you start looking at voltages on the solenoid and checking the earthing on the tractor frame.....will be a lot cheaper fix than throwing a battery at it only to find that was not the problem. Just a suggestion
   / battery spec for jimna tractors #4
Sounds more like a bad ground somewhere - most likely at the battery where the negative cable is bolted to the chassis. also check terminal connections.
   / battery spec for jimna tractors #5
On my '02 JM354 I put a Group 34 battery from O'Rielly's. It's been in there for three years. OEM was two 6 volts, Now one 12 volt. I'm using a Delco Remy alternator from a '80's chevy (SI-10 three wire I think). The only starting issues is that clutch pedal switch and I got to get that replaced "Again". My work around is to make sure the transmission is in nuetral and jumper the starter soleniod with a small chunk of 1 x 1 angle iron. "ain't easy bein' me". bjr
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
UNUSED FUTURE 15" EXCAVATOR GRAPPLE (A51248)
UNUSED FUTURE 15"...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A51247)
2017 CASE IH 580...
1320 Ford HST, 4wd Tractor (A52384)
1320 Ford HST, 4wd...
2025 SDLANCH SDLE18P UNUSED Mini Excavator (A53117)
2025 SDLANCH...
2005 DIVERSIFIED FABRICATORS FERTILIZER SPREADER (A51247)
2005 DIVERSIFIED...
