Battery Size Question - John Deere B
   / Battery Size Question - John Deere B #1
rmonio
Platinum Member
New Market, MN
JD 4600, JD B
Hello!
I just acquired a John Deere B (family heirloom) that has been restored and kept up-to-date. After transferring it home, we did maintenance checks (oil, filter, etc.) and found that the battery doesn't seem to be working very well. The battery is a 5V unit and there was question that it should be a 10V unit - can anyone confirm? I thought about buying a new battery - replacing the one that was in there - but wanted to know if was supposed to be a 5V unit.
We are also in the process of determining the SN/Year - someone painted over the tag and the stamp is filled with green paint (nice color, but we'll need to use a paint remover to get to the original SN). We think this is a '51 model.
Thoughts? Thanks!
-Bob
Hello!
Thoughts? Thanks!
-Bob
Got my answer. It's a 5V (unless you change out parts), it puts + to ground, and although they did at one time make 7.5V batteries you should stick with th 5V.
-Bob
   / Battery Size Question - John Deere B #3
:thumbsup:
A pic or two would be great, and would like to see it.
That 5v was a new one to me.
   / Battery Size Question - John Deere B #4
:thumbsup:
Same here, never heard of a 5V industrial battery. I have used 6 volts, 12 volt and even an 8 volt once to increase the starter capacity on a 12 volt system (one 8 and one 6).
   / Battery Size Question - John Deere B #5
-Bob
Bob
There's no such thing as a 5 or 7.5 volt battery for a automobile or tractor. Each cell(cap) on a lead/acid battery contains 2 volts so if it has 3 cells as your tractor should then it requires a 6 volt battery. Below is a serial chart so you can determine yr model of your B if it has a serial number tag.
   / Battery Size Question - John Deere B #6
lead acid batteries run 2.1 volts per cell, I agree with Jim most likely to be a 6 volt battery. A modern day 6 volt battery will blow away the batteries from the 1950's. Batteries have improved quite a bit over the years. Never heard of a 5v 7.5 or 10 volt lead acid battery either.
   / Battery Size Question - John Deere B #7
A BCI Group 1 battery will fit the box, be 6 volt nominal voltage, and a fresh one is all you need to roll your B over.
Sorry. I have been away. You were correct it was a missed type. It is a 6 V battery. It goes under the seat and fits snugly into the area where the battery is to go.
Thanks!
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51692)
2023 Stryker...
2019 John Deere 4052R (A50123)
2019 John Deere...
2012 Bomag BC572 Refuse Compactor (A51691)
2012 Bomag BC572...
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
John Deere 853 20ft Corn Head (A53473)
John Deere 853...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
