Battery recommendations: Brand-type-sizing
/ Battery recommendations: Brand-type-sizing #1
beowulf
Veteran Member
Central California Foothills
Kubota L3410 HST, J Deere riding mower
My Prostart Platinum bought on 1-7-2011 finally gave up the ghost (paid $97 at the time). I am looking to get an AGM type replacement. I have coupons for PepBoys (15% off plus $10 off) so hope they will have a brand that is satisfactory in a size that will work. I think they carry Bosch and Champion and Optima batteries and should have a size to fit.
Battery I have now is 8.75 long, 6.75 wide and 7.25 high but a larger battery will fit in the battery space as to length (up to 11.5 inches), and height (up to 8.5 inches with hold down). Width should stay at 6.75 inches to fit in the pocket. I found a BCI battery group sizing chart to help with that.
I want to go as heavy as possible and with a sealed AGM battery unless you all have suggestions to do otherwise. Hope to go to town tomorrow morning to get it so I can get back on the seat.
Thanks for any suggestions.
/ Battery recommendations: Brand-type-sizing #2
What kind of work does the battery do? Run lights with the engine off? Or just looking for cranking output?
My off-road rigs have optima batteries. I like them. They also make a coil type that has cylinder shaped compartments that are more vibration resistant than the plate style.
Most AGMs require a specific charger also, so look into getting something like a noco genius charger. I absolutely love them despite some people saying that they "dont work". My batteries consistently are outlasting the ones that used conventional chargers.
Marine batteries usually offer a good mix of cranking and deep cycle in one while also sporting higher quality lead (atleast here in Canada).
Hope this helps. Also look up the BCI battery group, you'll be able to find the group that your battery is and will be able to find more results or batteries that will fit inside the compartment.
Thanks for sharing that information. I am a bit amazed that the ProStart battery I am replacing lasted this long. It had a 72 month prorated warranty which it outlived. It had a date stamp (mfgr date or shipping date I am told) of 8/10 or August of 2010. I bought it in March of 2011. I don't think I have ever had a battery that outlived it's warranty.
I don't use the lights much at all. So, just used to start the tractor. Maybe that is why this one has lasted so long.
/ Battery recommendations: Brand-type-sizing #4
The key to getting the best battery life possible is to charge it once in a while, even if you use the tractor daily and to get a heated blanket for it if your winters are cold.
As far as those brands go, I wouldn't second guess any of the three but I personally have a couple of optimas which so far have lasted me for 3 years with no signs of wearing out on offroad rigs that shake, vibrate and have lights/radios running all the time..
/ Battery recommendations: Brand-type-sizing #6
I like the optima yellow top. I get as big of a battery as I can fit. Make sure you pay attention to the pos neg orientation of the cable connections. I had to do a little doctoring of my harnesses once.
/ Battery recommendations: Brand-type-sizing #7
I actually do not like optima batteries, some may disagree but that is okay. I prefer Odyssey Batteries. Now they make a quality battery and I've had nearly 8 years going on the same one.. My local speed shop sells the 'Deka' brand of battery, which is also a good battery.
/ Battery recommendations: Brand-type-sizing #8
There used to be a difference between rough and normal usage. Don't know if still pertains. Using a desulphating type charger may also help longevity.
Thanks guys for weighing in on this. I bought a Bosch Premium Performance battery with a 36 month free replacement warranty and a 96 month prorated warranty. Could not get an AGM in a correct size at Pep Boys but wanted to get a battery there because I could save a bit with coupon and reward card. It was $149.99 but with 25% off the first $100 and then another $10 off, I got it for about $115 plus tax.
The sales guy was surprised when I turned in my old battery with an August 2010 code on it - said it is really rare to see a battery that old turned in.
All installed and on the seat again.
/ Battery recommendations: Brand-type-sizing #10
/ Battery recommendations: Brand-type-sizing #12
Don't know how long my BX23 will go... but it has been amazing so far and I believe Deka
/ Battery recommendations: Brand-type-sizing #13
The sales guy was surprised when I turned in my old battery with an August 2010 code on it - said it is really rare to see a battery that old turned in. .
I had an OEM Motorcraft (Ford) go 15 years. Always garaged (unheated)
/ Battery recommendations: Brand-type-sizing #14
When I had to replace the battery in My NH TC33D for the second time, I used an Optima yellow top D51 battery. Dimensions were Width: 5.06", Length: 9.31", Height: 8.94" (height includes battery posts). These dimensions were close to the OEM battery, so it fit well. CCA rating was better than the OEM.
Beowulf, it looks like an Optima Model D75/25 might fit you: Width 6.81" Length 9.38", Height 7.75 in (CCA 620 Amp).
Some of the reasons I went with Optima:
  • They can handle vibration much better than flooded lead-acid batteries
  • The optimal charging and float voltages are the same as for flooded lead-acid batteries, so I don't need to use an AGM-specific battery (Oddesey brand AGM batteries call for different charging and float voltages)
  • It's a dual purpose battery, suitable for both starting and deep cycling. I don't do a lot of deep cycling, but figured it couldn't hurt for those rare occasions when some activity or another ran it down, or if I add other accessories that put a significant load on the battery)
  • AGM batteries in general tend to self-discharge more slowly than flooded lead-acid batteries, so there is less chance of finding a dead battery if for some reason I don't use the tractor for an extended period.
I'm just coming up on 2 years with the battery, so it's too soon to tell how well it will hold up in the long term. I've had no problems so far, though, and have had good luck with them in other applications.
UNUSED INDUSTRIAS AMERICA F08 HYD TILT LAND LEVELE (A62130)
UNUSED INDUSTRIAS...
UNUSED KIVEL 48" PALLET FORKS (A62130)
UNUSED KIVEL 48"...
240 Massey Ferguson Tractor (A61166)
240 Massey...
2017 Dodge Journey SUV (A61569)
2017 Dodge Journey...
John Deere 2355 Tractor (A61166)
John Deere 2355...
2007 Volvo VNM T/A Day Cab Truck Tractor (A61568)
2007 Volvo VNM T/A...
