Battery powered grease gun recommendations?
   / Battery powered grease gun recommendations? #101
You know, I have a grease gun that took some kind of 12 or 14 volt batteries that I picked up off the side of the road. I also have various Ryobi flashlights and stuff that could probably be sacrificed for such a cause...
Aaron Z
It was actually, pretty easy to do.
There are adapters for the various 20ish volt batteries out there. That one looks almost OEM though. Nice work.
Badaptor Dewalt 18V/2V Battery Adapter to Ryobi 18v One+ Tool | eBay although that one is kind of backwards for me. Flat faced batteries are easier to adapt than batteries with a post on them (like the One+ ones). Pile of files to print the adapters out on a 3d printer too on thingaverse or what not.
   / Battery powered grease gun recommendations? #103
I've always had Craftsman cordless tools but in searching for a cordless grease gun I decided to switch to Dewalt. Ordered a combo kit with the 20v grease gun, 1/2" impact wrench, and worklight. Got the Lock n Lube also. Looking forward to the grease gun. I've used the typical manual gun for many years, tried a cheap Central Pneumatic air gun, which was more of a PITA than what its worth. From what I see here the Dewalt should be the ticket. I have 32 fittings from the FEL to backhoe, several on the dump trailer, atv's, etc. It should get a workout now and then. I'm anxious to try out the 1/2" impact on lug nuts too.
   / Battery powered grease gun recommendations? #104
Aaron Z
I don’t know how your luck would be on some oddball battery but you can buy adapters for the more common brands.
   / Battery powered grease gun recommendations? #105
We do industrial forestry with different brands of battery powered grease guns, the dewalt 20v is ok once you plug off that relief valve, the Milwaukee 18v is a lot lighter as well as faster plus a few extra features, and an alemite that’s given us really good service as well. Most days they are used for an hour with about 10 to 40 tubes ran through them weekly.
   / Battery powered grease gun recommendations? #106
I had not seen those.
Yeah, an adapter to put a Ryobi battery on a Dewalt tool would seem to be a better idea.
But, I would never need it.
   / Battery powered grease gun recommendations? #107
I ended up getting the Milwaukee 18v. Good unit! Loads up easy, well made, and the air purge button works.
Couldn’t wait any longer on Makita to release theirs- so I got the battery adapter from Amazon.
Makita batteries in my Milwaukee.
Used it on my truck with the Lock n
Lube- worked as advertised!
Haven’t used it on the tractor yet.
( It’s still strapped to trailer I brought it home on )
   / Battery powered grease gun recommendations? #108
Excellent choice! You will only need to purge the air the first time you put a cartridge in. Get a Lube Locker, makes greasing much easier.
   / Battery powered grease gun recommendations? #109
Whether I'm using the "standard" zerk adapter, the needle point or the LockNLube adapter - the DeWalt battery grease gun is like having an extra set of hands. Just let the grease gun lie on the ground - make connection - find the trigger with the off hand.
Trying to keep the adapter in place and then pumping a handle can become a problem. I'm speaking mainly of those zerks that only an articulated monkey could reach.
   / Battery powered grease gun recommendations? #110
Yes!! Loving my DeWalt. Great for tough to reach zerks. I have about 100 of em! :yuck::yuck:
500 GALLON FUEL TANK ON SKID (A52708)
500 GALLON FUEL...
Set of 4 12-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 12-16.5...
Kuhn Knight Verti-Max 5032 (A57148)
Kuhn Knight...
JOHN DEERE 850K LGP (A58214)
JOHN DEERE 850K...
1714 (A58374)
1714 (A58374)
Year: 2007 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2007 Make...
