Battery powered chainsaw recommendations? (2017)
/ Battery powered chainsaw recommendations? (2017) #121
I've been impressed with the 40v Lynxx pole pruner I got from Harbor Fright. I've yet to have the battery go below 'full' even after sawing though a bunch of large limbs. The only problem has been the oil tank is easy to overfill and leaks if it's full and you store the unit upright. I'm sure the Stihl unit is much nicer though.
/ Battery powered chainsaw recommendations? (2017) #122
I may just get one and try it. My B&D 18V polesaw has been useful, but oiling is manual and the batteries
are getting old. Great for limbing in the gulches, esp with all the poison oak.
The other possibility is the Ryobi One + LiIon polesaw which is similar price and voltage. Anyone try that?
/ Battery powered chainsaw recommendations? (2017) #123
I have a cheap manual oiler polesaw too. I tried using it for PO and got a terrible case of it. The chainsaw sprays that stuff everywhere and being on a stick doesn't put it far enough away from me. But I'm very sensitive to it.
/ Battery powered chainsaw recommendations? (2017) #124
I have the Ryobi pole saw and it works very well. Also have the hand held Ryobi blower, and work station radio. Ryobi is tops on my list.
/ Battery powered chainsaw recommendations? (2017) #125
I have a 58v echo 16? It plows through anything I throw at it. The only limitation seems to be the length of the bar.
/ Battery powered chainsaw recommendations? (2017) #126
I have one, It works pretty well, but seems to leak oil in storage. Best to run it until out of oil and then store it. I need to look into the leaking and see what and why.
/ Battery powered chainsaw recommendations? (2017) #127
I have one too, does your leak during long term storage? Please let me know. If your doesn't leak, I will tear into mine and see what I might do to fix it.
/ Battery powered chainsaw recommendations? (2017) #128
I don't use a chainsaw for poison oak, unless it is several inches thick. I have seen it up to 4" thick. I use a manual
lopper for most of it. No weed-wackers, no mowers, nothing that slings it around. Nasty stuff.
Mostly, I am trying to get around it to cut other stuff with the pole saw, or to save climbing into swales,
or bending over.
/ Battery powered chainsaw recommendations? (2017) #129
I'm terribly allergic to poison ivy. I've cut quite a bit of it with a chainsaw in month old logs. It must loose effectiveness once it starts to dry out.
/ Battery powered chainsaw recommendations? (2017) #130
Ryobi: I have the older blue 18 volt chainsaw. It's excellent for clearing the punky downed apple trees in the orchard, 99% of its use here, but it's working hard in larger hardwood such as Eucalyptus. Think of it as a pruning saw, not a firewood saw.
And it leaks oil. The oiler is a rubber bulb on the fill cap and that soon tore. I replaced that, thinking that's where the oil escaped in storage, but no. So I store it nose down in its plastic sheath, carried in a plastic bucket. When cutting, oil the bar frequently with a squeeze bottle (like restaurant mustard).
Poison Oak: Yes the pole saw, or loppers. I've read the oils are in all parts including roots, and stay toxic for years, so even dry dead wood can get you. Don't burn or chainsaw it! I wear knee high rubber 'milking boots' when I can't avoid going into it.
/ Battery powered chainsaw recommendations? (2017) #131
Both my Ryobi, and EGO leak badly in storage. I try to drain all oil first.
/ Battery powered chainsaw recommendations? (2017) #132
So far, I've never had a battery powered chainsaw, but I've owned at least 3 or 4 gasoline powered saws and two 120V corded electric. And never had one wouldn't leak in storage unless I drained it before putting it away.
/ Battery powered chainsaw recommendations? (2017) #133
My understanding is that all chainsaws will leak oil. The oil is fed through an open channel to the chain. In operation it lubricates. When off it leaks. The vibration increases in running leads to a faster flow - just like shaking a bottle of water with a tiny hole.
I've never heard of their being a shut off valve on the oil reservoir. I think of chain saw oil leaks as a fact of life and plan accordingly.
/ Battery powered chainsaw recommendations? (2017) #134
I had sears chainsaws that made a mess... no wonder they come with a case.
I always keep a saw in the truck... the little Echo Top Handle saw was the first NOT to make a mess...
Had if many years now and even took down a 38" pine that was a hazard... way more than it should but I was helping a friend and it was the only saw I had with me...
Poison Oak... loppers or chemical... I get poison oak from just the dust running the dozer!!!
/ Battery powered chainsaw recommendations? (2017) #135
My Oregon 40 Volt Pole saw and chain saw don't leak at all. In fact, I wonder if the oiler works on the pole saw, as the oil never goes down.
My Junky Stihl 034, 036 and 017 leak (from day one) til their empty. I find laying them on their sides helps, so you can pretty much throw away those plastic cases. I don't think my Electric 110V Stihl leaks come to think of it.
/ Battery powered chainsaw recommendations? (2017) #136
I do not have battery powered saws, just wanted to post even expensive PRO saws leak bar oil. Everyone of these leak, they are worked but pampered and they still leak. Nature of the beast.
/ Battery powered chainsaw recommendations? (2017) #137
JD put some stupid little bottle with hoses running from the aux couplers to catch the few drops of oil that might be lost. I can't believe for the life of me, that the VERY ecologically minded Germans (except for the automakers) have not addressed this most annoying issue.
/ Battery powered chainsaw recommendations? (2017) #138
They are just marking there territory, hahaha.
/ Battery powered chainsaw recommendations? (2017) #139
Maybe some, but I got a really really bad case of it when I cradled some old limbs that had the PI vines on them that I had cut over two years previous on my bare arm. A really really bad idea.
KUBOTA SVL97-2 SKID STEER (A65053)
KUBOTA SVL97-2...
2009 Caterpillar 345D Hydraulic Excavator (A64553)
2009 Caterpillar...
2025 LandHonor LHR-G209 Anchor Shackle Set (A64194)
2025 LandHonor...
2019 CIMC 40ft. 36 Ton T/A Container Trailer (A64556)
2019 CIMC 40ft. 36...
2013 Nissan Pathfinder SUV (A64557)
2013 Nissan...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
