battery overcharging
   / battery overcharging #1
marler
I have a LK2554. I am getting 17.5 volts while the tractor is charging. I just replaced the alternator. Still getting 17.5 volts or better. Where else can I check?
   / battery overcharging #2
If the battery has a shorted cell it can cause an excess voltage draw so alternator would be put out extra volts trying to keep up.
   / battery overcharging #3
What is the battery voltage while the tractor is off?
   / battery overcharging #4
I had to jump my tractor. This was a few years ago but seem to recall that the charging voltage was way high. New battery and the charging voltage was fine. I would not put a new alternator on without having the old one bench tested. Way too much money to toss around.
I just put my 2nd battery in two years in. The Alternator is brand new. I am getting 13.3 volts with the tractor off
   / battery overcharging #6
Most battery chargers now have a battery and alt test mode. I would look into one before a battery or alt. They are much cheaper and can be used on about any thing.
17volts does seem a little high. Should be more like 14/15volts.
no more ideas?
   / battery overcharging #8
If your measuring voltage at the battery you should have 12.5 to 13.5 with engine off. Fire up engine and your voltage should jump to 15.5 or so volts. As the engine runs the voltage should drop to 12.5 to 13.5 volts. If your voltage does not drop after engine is running for a bit your voltage regulator is not working.
   / battery overcharging #9
17.xx is way too much output- enough to cause the battery to explode and throw acid all over you and everything else around it. While wearing safety glasses, long sleeved shirt and gloves, CAREFULLY remove the negative battery terminal and then the positive and place the battery in something safe, (HD plastic or wood crate or something similar, with a blanket or some such thing to cover it during transport). Have it load tested at a local facility after explaining what its been reading at 17.xx volts. Evidently the alternator is not your issue. By load testing the battery and checking the specific gravity of each cell you will be able to rule out the battery or find that it is indeed the problem. Report back results, and be careful; no one wants to experience a battery explosion under any circumstances.
When the engine is reved up to about 1500 rpm I am getting 17.5. At idle it is 15.3. This is after letting the motor run for about 5 minutes.
2017 Ford F550 Bucket Truck - Powerstroke Diesel - Auto Trans - 4x4 - Versalift SST40 Boom (A52748)
2017 Ford F550...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A52748)
Kuhns AE10 Small...
New/Unused 12ft x 7.4ft x 8.2ft Container (A51573)
New/Unused 12ft x...
1999 KENWORTH W900 TANDEM AXLE SLEEPER (A52576)
1999 KENWORTH W900...
2016 JOHN DEERE 135G (A52472)
2016 JOHN DEERE...
