battery not charging
   / battery not charging #1
stykemainb
Davisboro,Georgia
JD X500, JD M 40T Tricycle
I just charged up my battery for my x500 and after a couple of hours or so the tractor stops and the battery is dead again but after I charg the battery it starts again any Ideas? Could it be the voltage regulator?:confused:
   / battery not charging #2
If it's under 4 years old, it's still under warrantee... If not, you'll need to grab a meter & start troubleshooting the problem. I've seen some good troubleshooting videos on Youtube. Might be a good place to start.
If your battery is more than 3 years old it is definitely suspect.
   / battery not charging #3
Check for loose fan belt, a wire pulled loose by a limb or stick, or corroded or loose battery cable at one end ,possibly at the ground to frame.
   / battery not charging #4
Take the battery to a local Autozone and have it tested for free. They will do the same for your alternator. It does sound as though the tractor is running till there is no electric.
   / battery not charging #5
Put a volt meter on the battery post's, not the end cables,
check for a charging voltage when running, if its not charging, your regulator or alternator could be gone.
   / battery not charging #9
What is the battery terminal voltage at slow and fast idle? Sounds like a total failure to charge. Any chance the battery was low this spring and somebody boosted the tractor to start ?
   / battery not charging #10
Had the same problem on my Ford toward the end of this past Winter. Discovered a plug connection that had a little dirt/corrosion. A little cleaning and it was back to normal.
LOAD OUT INFORMATION (A53084)
LOAD OUT...
1992 GROVE AP-308 CRANE CRANE (A53426)
1992 GROVE AP-308...
Frontier 60" Grapple (A50123)
Frontier 60"...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
2012 Ford F-450 Knapheide Service Truck with Liftgate (A51692)
2012 Ford F-450...
