Battery maintence Tie multiple batteries together
   / Battery maintence Tie multiple batteries together #1
ibboatin28
Rather that buy 5-6 battery maintainers is it possible to tie my 2 John Deers my Generator, and my sports car etc. Together to maintain the batteries with one small charger? I realize if I have one bad battery it will drain the rest of them but mine are all fairly new. I'm thinking a 1.5 amp float charger. Is it feasible?
   / Battery maintence Tie multiple batteries together #2
just take turns and charge each battery with the same unit .
   / Battery maintence Tie multiple batteries together #3
I don't really know for sure, but I've been using one maintainer on my two RV batteries for three years now. I check them every 6-8 weeks and they're always topped off.
   / Battery maintence Tie multiple batteries together #4
Some chargers are rated to maintain multiple batteries but I think 5 or 6 would be pushing it especially with a 1.5 amp maintainer. I would check to see if yours is. You could also get one of those multiple bank units but they are about expensive as buying individual chargers.
Thanks for the replies guys. I'll probably just buy more trickle chargers.
   / Battery maintence Tie multiple batteries together #6
If you are storing a battery for the winter, and the battery is fully charged disconnect the ground, you do not need a battery maintainer. Leave in the vehicle in the cold. It will actually last longer. A battery maintainer keeps the electrons in the battery excited/warm moving around decreasing the life of the battery. Actually fully charged stored in the freezer is the best place, so grandpa was right.
Now if you have to leave the ground connected and have to run say the clock in the radio different story. Then you need the maintainer.
Steve
2007 MACK CXN TANDEM AXLE DAY CAB (A53426)
2007 MACK CXN...
Alliance Flotation Tire (A50123)
Alliance Flotation...
2011 WABASH 53x102 DRY VAN (A53426)
2011 WABASH 53x102...
2004 Ford F-550 4x4 Auto Crane 4004EH 2 Ton Crane Service Truck (A51692)
2004 Ford F-550...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
2015 Dodge Journey Van (A51694)
2015 Dodge Journey...
