battery light when pto switched on
   / battery light when pto switched on #1
jimmysisson
W.Mass
1993 NH 2120 (the best), 1974 MF 135 (sold, but solid), 1947 Farmall A (bought, sold, bought back, sold again), 1956 MH50 lbt (sold, in 1980, darn it)
My 1994? Cub Cadet 1440 is solid and dependable. That said, when I switch the pto on for the deck, the battery light stays on for maybe 6-8 minutes, then goes off. Headlights on won't make that happen, unless the battery is weak. I replaced the pto clutch maybe 40 hours ago (total ~500 hours now). Anyone know why this might happen? No other symptoms I can see.
Thanks, Jim
   / battery light when pto switched on #2
Thanks, Jim
I would start by starting it with another battery but would avoid buying a new one.
If not start it up with another battery with jumper cables attached to your battery and start and see if light comes on with other battery in line.
If battery on another vehicle,tractor,etc do not start other motor. I believe the pto switch is or does pull more than lights on.Just a thought.
Boone
Thanks. My CC starts just fine - would the second battery just provide backup amp-hours? I'm not sure if the pto switches on any other circuit. I know the pto switch itself is questionable. It tends to kick off when I first switch it on, and I have it held up with a rubber band to the throttle lever. Hmm, maybe that's the problem - a poor contact through the switch? Except that the light blinks and the electric pto clutch stays engaged. Maybe I'll try a new switch and see what happens, since I need one anyway.
Jim
   / battery light when pto switched on #4
I dont have a battery light but an ammeter on my 1811, but early this year I was mowing and the PTO just stopped when mowing. Come to find out the battery wasnt holding a charge due to dead cells after 8 years even tho it was getting 14.5 V charging.
After I replaced the battery no more problems. Most auto parts stores will test it for free and I bought a new battery at autozone for $40 - the old one wouldnt even register on the tester it was so dead.
the switch also might have a weak contact so replace the switch and test the battery.
   / battery light when pto switched on #5
I'm unfamiliar with your specific year/model, but in this class of tractor and mower most PTO switches are very similar; when you operate that switch (close it) you send power to a large electric solenoid that engages a drive clutch. That solenoid, all by itself, is a substantial electrical load and it will tax a charging system if it isn't in top condition.
As mentioned above, you might need to check the condition of your battery. Most auto parts jobbers will do this for free. If it passes a load test, you'll also need to test the charging system to rule out the alternator/voltage regulator.
But before you do any of that, check the condition of the cable connections. A poor connection can cause a voltage drop. Chekc at the battery (both -ve and +ve), at the engine block ground, and at the starter and starter solenoid. Then check the smaller wires at the PTO solenoid/clutch. If they are all good, clean and tight, then pull the battery and load test it.
Likely it is the battery - an inexpensive fix you can do easily yourself.
2017 Dodge Charger Sedan (A53424)
2017 Dodge Charger...
2000 GAL FUEL TANK (A53843)
2000 GAL FUEL TANK...
2019 Doosan LCV6W Towable LED Light Tower (A54811)
2019 Doosan LCV6W...
2013 KENWORTH T680 TRI AXLE SLEEPER TRUCK (A54607)
2013 KENWORTH T680...
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A53426)
2007 PETERBILT 379...
2015 Toyota Prius (A53424)
2015 Toyota Prius...
