Battery light indicator.
   / Battery light indicator. #1
rfkulka
Orange CT
John Deere 650
Started my newly acquired used B7800 today. I noticed the battery light indicator stays illuminated while the tractor is running. Is this normal or an omen of a possible problem. I"m new to the machine and being such a novice is embarrasssing. I'm thinking it may be an alternator issue or maybe no issue at all. Can anyone put my mind at ease? Should I check the charging with an ammeter. The owners manual does not address the issue. Thanks for any any info you care to share. I will be appreciated.
   / Battery light indicator. #2
the light should go out after a bit, check with a voltmeter. volts will go to 14 or so then settle down to 12.5.
2015 FORD F250 SUPER DUTY EXT. CAB (A53843)
2015 FORD F250...
434669 (A48836)
434669 (A48836)
2014 Ford F150 Pickup Truck (A53422)
2014 Ford F150...
2014 Peterbilt 320 Altec AH150 150ft. Material Handler Bucket Truck (A52377)
2014 Peterbilt 320...
Mini Excavator (A52377)
Mini Excavator...
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A51692)
2014 Utility...
