battery life
/ battery life #11
I think this is the norm, one year on a new battery.
Curt
/ battery life #12
I still have the original battery in my 2518. No problems yet. I guess this spring I will seee what happens!
At least for me, if I have to get a new one it will depend how much cash I have in my pocket at the time. In this economy who knows!
Michael
/ battery life
The first battery lasted 3 seasons. I went to Tactor Supply today and bought a Huskie battery for $37 and the tractor starts like it's new again. I didn't realize that the battery has been deteriorating probably for the the last year.
/ battery life #14
May I suggest that you all that are having problems with battery life, get a ADC 1.3 AMP pulse charger from Northern Tool or other source.
I have auto "type" batterys which are maintained on this brand of charger maintainer. 2 of them lasted over 10 years. Use of a pulse maintainer helps to reduce or even reverse sulfation which in the long run, helps to cause cell shorts. 167981 or even the 2/4/8 amp 167988. The last will also work with other types than standard auto styles. IE. GEL and AGM etc.
/ battery life
I always get many years of service out of auto type batteries and this battery is the first one that ever gave me dissapointing service. I am certain that is is what has been discussed, it came with a cheap battery.
/ battery life #16
I was curious about my battery so I went out and it started right up. Hopefully I can expect the same in a few months!
Michael
/ battery life #17
I'd loosen & clean connections before buying a new battery. Lots of connections only get cleaned when a new battery is installed thus masking the real problem. In most cases when jump starting the battery terminal is bypassed and the jumpers make contact with the battery leads to the starter and a quick start occurs, but the alternator still has to charge thru bad connections, which it won't do, making the battery look like the culprit. Particularly with small batteries the charger clamps onto both the lead & battery post also bypassing the bad connection making it appear that the battery will take a charge but won't hold a charge. i.e. charger brings charge up, gets disconnected, tractor starts discharging the battery, and because of bad connections the alternator won't recharge. MikeD74T
/ battery life #18
Keeping the water level at the correct level on batteries (none gel type) is important for long life. Most people dont look at them till they wont start. Even the so called maintenance free ones will require some water if they have caps which many of the automotive maintenance free batteries do. They dont loose as much as the old type but they still loose some water over the months and years. Cleaning the battery post connections is probably the biggest culprit to a discharged battery. The alternator wont put a charge through Lead oxide, so occassional cleaning is necessary. Adding some antiox compound will help keep the connections clean for much longer or if you cant find the anti-oxidant compound just put a generous amount of lube grease on the terminal to keep the air and moisture from it will help too.
/ battery life #19
I had my 06 Suburban in the shop today, 10 days left on the warranty. They replaced the battery and one of the fobs. Less than 3 years on a Delco battery, sounds about right.
China syndrome!
Curt
/ battery life #20
I just replaced the battery last month in my 2000 Cadillac, which was the original Delco. It suddenly wouldn't crank and when I pulled on the cables the positive terminal came out in my hand with a piece of the battery attached to the cable bolt. I figure it didn't owe me anything after 8 years but they may have been better batteries back in 2000. The replacement cost me $175 at Sears. It's a 1000 CCA large vented battery which mounts ynder the rear seat.
Bob B.
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A61307)
2006 Heil Tanker...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
TOYOTA FORKLIFT (INOPERABLE) (A60736)
TOYOTA FORKLIFT...
2001 PETERBILT 379 (A58214)
2001 PETERBILT 379...
