Battery JD 1010 gas
   / Battery JD 1010 gas #1
bschulte
John Deere 1010
I've acquired a John Deere 1010 gas powered tractor. The battery is 8 y old and now dead. It appears to be a truck battery. An auto store said it wasn't the best for field work because the cells were not self-contained and likely one broke down and went bad. Any suggestions on the battery I should purchase. The tractor is used 5-10 x per year for bushhogging. Prices at auto stores and a john deere outlet range from $90-110 on a battery similar to what was in it. For this money, I want to make sure I'm buying the correct battery (and would love not to spend this much!). Thanks.
   / Battery JD 1010 gas #2
I would suggest going to Costco or any store with batteries. As long as the demesion is the same for the amount of use you need the tractor.
That 1010 is an awesome machine, my Father-in-Law had one many years ago, and sold it to get a MF (bad decision). Wish he kept it.
Good Luck
   / Battery JD 1010 gas #3
You will get a longer life out of an off road battery. Does not have to be Deere. The off road batteries are made to take the shocks and vibration that you will expose it to.
2014 Top Hat Industries 18FT T/A Utility Trailer (A52377)
2014 Top Hat...
UNUSED SWICT 84" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 84"...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
JOHN DEERE 2750 TRACTOR (A54756)
JOHN DEERE 2750...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
