Battery issue
   / Battery issue #1
CT230 Fan
Stewartsville, MO
Bobcat CT230
Well, everything had been going great with my CT230, until I tried to start her up on Saturday. When I turned the key, the tractor made some strange noises and the lights on the dash were dim and flickering. So, I figured the battery must have been run down, so I went to put the charger on it, and popped open the protective cap on the positive terminal and saw that it was completely full of corrosion. I went ahead and hooked up the charger and let it complete the cycle. Same problem when i tried to start it again, so I proceeded to loosen the clamp and it just fell apart on me.
I have a replacement on order, but I can't imagine why the battery would have that much corrosion.
   / Battery issue #2
I only have 35 hours on my CT235 and after reading several threads on the leaking battery acid decided that I didn't want any part of it and replaced it with a Sears Diehard Platinum P-1 - Maintenance free battery. I started to notice corrosion with the original bobcat battery within 10 hours. Since I replaced the battery tray looks like new, no corrosion and so glad I made the change. I would just go ahead and go with a maintenance free battery so you don't have to go through that again. It will put you back about $200, but you shouldn't have that issue come up again.
   / Battery issue #3
Looks like the battery is being overcharged, and the off gasses are getting trapped in the protective cap.
   / Battery issue #4
Yes, I would check the charging voltage, it should be between 14.00 to 14. 3 normally. 14.5 to 14.7 will cause gassing and 14.7+ is an overcharge condition.
   / Battery issue
Not to sound completely ignorant, but how do you check the charging voltage? Check it while the tractor is running? I have never had to manually charge the battery.
   / Battery issue #6
Use a voltmeter at the positive & negative posts with engine running about 1/2 throttle, then at full throttle to make sure regualtor is working correctly.
   / Battery issue
I will check that out as soon I can get the new battery cable in and installed. They said it should be in Wednesday. I hope so, my grass is getting pretty tall.
   / Battery issue #8
Yeap. My battery leaked all over the engine compartment and made a huge mess. I went with the Sears Diehard Sealed maintenace free battery
after cleaning up the mess and painting.
A sealed battery is peace of mind.
   / Battery issue #9
Thanks for the posting. My CT 230 is 7 months old and has 54 hours on it. I checked the terminals and the positive was corroded. I scraped it and soaked it in baking soda, greased it and put it back on. I don't really want to buy a new battery so soon. I will keep an eye on it and even if your tractor is new I would check this out. I was surprised by the ammount of corrosion that was there.
   / Battery issue #10
I guess I was lucky with this problem. My battery died suddenly about 8months ago. It hadn't leaked or anything ... just died. The dealer replaced with a new battery and all has been well. No leaks or issues.
MoKelly
2019 Nissan Sentra Sedan (A50324)
2019 Nissan Sentra...
2008 Bobcat S250 Skidloader (RUNS) (A50774)
2008 Bobcat S250...
2011 Ford F-250 Ez Dumper Dump Truck (A50323)
2011 Ford F-250 Ez...
1261 (A50490)
1261 (A50490)
New Holland TN60A (A50120)
New Holland TN60A...
JLG 20MVL Electric Vertical Mast Lift (A50322)
JLG 20MVL Electric...
