Battery goes dead
/ Battery goes dead #1
Dave.S
Mahidra 3550 HST T4 open station
I have a 3550 HST tractor and recently the battery keeps dying when parked. I disconnected the - cable and put a test light between the cable and battery. Test light glows brightly. I pull every fuse one at a time and any relays I could find by the radiator and each time the light did not got out. I even removed the wiring to the ignition switch and the light still stays on.
any ideas as to where to look for the draw? Also I am looking for the wiring diagram for the tractor. I found one in the service manual but the PDF is unreadable.
/ Battery goes dead #3
Try jiggling/massaging the harness at any sharp turns, tight attachment spots or places it goes through the firewall while you watch the test light. You probably have some worn/torn insulation & a short inside the harness between two wires. If that doesn't reveal anything, next step is to open up the harness & see if you have worn wires ... can be a long tedious process that might get sped up with an infrared thermometer to identify hot spots in the harness.
/ Battery goes dead
Thanks for the replies I'll try both. how much amperage is acceptable? I know the computer needs to keep going and I checked all fuses with a test light with the key off the on fuses with power were the flasher lights and I think the ecu.which are the the bottom left fuse for the hazard light circuit and the top left the one I can't remember what circuit. When I put my multi meter between the cable and - terminal it read full battery voltage.
any Ideas about where to get a wiring diagram?
/ Battery goes dead #5
Depending on how long it takes the computer to go to sleep, with everything off, you probably don't want to see more than 15 or so milliamps, and down around 5 would be better. If you are seeing higher draws than that, you have a short, wiring problem, or a stuck component switch. You said pulling fuses didn't change the test light, so, if it was me, I'd concentrate on the wiring before the fuse panel, and check for any spots that could be shorting to ground. Then, you could also try disconnecting components one at a time to try & isolate the problem, starting with the alternator/voltage regulator.
Have you load tested & visually inspected the battery itself? I had a chevy tahoe with relatively new (2 year old) battery that I was convinced had a parasitic draw problem, based on the same results you are showing (dead after 20 hours, voltage differential between post and cable, fluctuating amp draw north of 1.5 amps) but I couldn't find a bad circuit. When I pulled the battery, I saw significant swelling on one side that was hidden while it was bolted into its box. Wound up being an internal short between plates in the battery. Battery load tested well initially, then didn't.
/ Battery goes dead
I think I may disconnect the alt just to see if the test light goes out and check for pinch points in harnesses for shorts.
Alt charges at around 14 volts and battery will start motor if unhooked when done working for the day and starts motor when using tractor in the field,
but is an old battery marine deep cycle that I used on a kart for jump staring. hard working on electric gremlins with out a diagram so I know what circuits have power all the time. Thanks
/ Battery goes dead #7
An idea,
I had a similar issue with my Mahindra 2538.. turned out to be the Ground Strap to the frame. Took it off, cleaned both ends to spotless.. and the related connection on the frame where it connects, with a grinding wheel .... no issues since
/ Battery goes dead #8
Dave, not sure if you tried the alternator yet but my bets are on the diode inside it being shorted. Fairly common on vehicles.
Good luck...........
/ Battery goes dead #9
i have a 3550 pst cab, i had your exact symptoms for a few months. i chased all the things you did. i could run the tractor and battery would charge and re-crank after running even with A/C. (in hindsight not nearly as well as i thought). it falsely led me to believe i had a parasitic draw. turns out the $200 interstate battery less than a year old AND testing at 12.4 volts was only making 300+CCA. it's rated for 950 CCA. check the battery. i purchased a battery tester on Amazon for $20 but Harbor freight sells the viking one for $40. pull the battery charge overnight then test. new battery tested @ 1049 CCA. <stays hot and spins that motor right over. Glad my fix was this simple, hope yours is too. if this isn't the problem there's a wiring diagram in your user manual. if you dont have that, go to mahindras website under owner resources you can type in your serial number and get the manual in a PDF. save that file to your phone to keep.
/ Battery goes dead #10
Sad state when batteries that should be in their prime are not.
For decades starting in the 70’s we sold Interstate and very rare to have any issue.
Sadly the last few years before we dropped them had problems and Interstate would blame modern vehicles with always on electronics…
/ Battery goes dead #11
Yea my 08 f250 had to warranty 2 sets of interstate batts. then burn up an alternator when a cold front killed one overnight. interstate said there was an issue with my truck..... i put Walmart batteries in the Ford and they've been good for years. this Interstate batt came with the tractor and still had full replacement warranty so i replaced it with another, but I'll never purchase an interstate battery again. ill give credit where credits due its testing higher than the CCA rating of 950, but i have no bassis on whether or not the Amazon batt tester is 100% accurtate. if you can get your hands on a Deka type 31 that would be my 1st choice, my local battery shop has them for $131 and the AGM for $289. Napa/Autozone/ O'reileys have the type 31 battery for about $180. Walmart dont carry a type 31 battery or i would have explored them too. I've had great results with Deka in my atvs utvs
/ Battery goes dead #12
My longest lasting ever battery is Deka
/ Battery goes dead #13
allegedly made in PA
/ Battery goes dead #14
no update?
/ Battery goes dead
Took the alternator wire off and test light went dim, so i removed the alt and took off the plastic cover.
found some rust on some of the screws for the brushes and connections. cleaned it up and also found insulation on a (guessing a heat sink) brittle
so I covered the wire with electrical tape. heat sink goes to the lower brush and then the brittle wire goes to an electrical connection.
Put all back together, and the test light only had the dim draw and put the - cable back on the new battery I put in. before taking off the alt. it would only charge at a slow rate and took about 5 minutes to get to just about 14 volt charging. after cleaning and reinstalling It charged quickly but went up to 25 volts and still climbing when I shut it down. will be installing a new alt. and I let you know.
By the way the alternator was hot to the touch and much hotter than any surrounding metal, so I think it has a short inside of it. Also on the plastic rear cover it says fuse inside, anyone know what it looks like? It is a Lucus alternator.
2018 BOBCAT E45 EXCAVATOR (A59823)
2018 BOBCAT E45...
2016 FORD TRANSIT T250 CARGO VAN (A59575)
2016 FORD TRANSIT...
2020 Deere 544L (A60462)
2020 Deere 544L...
2008 CATERPILLAR M322D MOBILE EXCAVATOR (A59823)
2008 CATERPILLAR...
2017 Kustom Signals Towable Solar Radar Speed Limit Trailer (A59228)
2017 Kustom...
2017 John Deere 6120E (A53317)
2017 John Deere...
