battery for B5100E
   / battery for B5100E #1
stearnser
I just got a B5100E and I need to replace the battery (the one in it is 365 CCA and is dead). The owners manual doesn't say much about what type of CCA I should be looking for. I would rather not go to the Kubota dealer to get the battery unless I have to. Anybody got any advice or specifics (size, model numbers, etc). Thanks.
   / battery for B5100E #2
I have an Interstate battery in my B7100. They were the only ones around here that had the small size I needed with enough cranking amps for a diesel engine. My Kubota dealer only uses these as well. I use my tractor all year and with well below zero temps I could not get away with using a less powerfull battery.
Hope this helps
Scott
   / battery for B5100E #3
optima all the way
PS welcome to TBN!
   / battery for B5100E #4
I went through the same thing 3 years a go with my B5100. I could not find the right type of battery at my local farm and ranch supply or at the auto parts store that carried Interstate batteries. I finely settled for a Duralast Gold battery I found at a second auto parts store. Other then what I paid for the battery I can not complaints about it.
If you still have not found a battery and would like to know what model I have let me know. I will take the hold down bracket off mine and get it for you.
Rsislo
Thanks, this is a great forum, helpful and informative. Rsislo, I sent you a PM.
2005 International 4200 Texoma UC-301 Pier Drilling Truck (A49461)
2005 International...
2025 LandHonor LHR-EW20000 20,000lb Electric Cable Winch (A49461)
2025 LandHonor...
2008 FORD F-350 (A50854)
2008 FORD F-350...
2025 78in Rock Bucket Skid Steer Attachment (A50322)
2025 78in Rock...
2015 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51219)
2015 FREIGHTLINER...
2014 FREIGHTLINER M2 DAY CAB (A51222)
2014 FREIGHTLINER...
