Battery exploded, every one is ok so far
/ Battery exploded, every one is ok so far #21
Ultrarunner,
That's scary. Are you still deaf in one ear?
/ Battery exploded, every one is ok so far #22
The only time it happened to me was disconnecting a fast charger that WAS unplugged.
I never charge on anything but the low 2A setting. Never.
/ Battery exploded, every one is ok so far #23
Ultrarunner,
What????
I do have slightly less hearing in that ear and I attribute it to that....
I was so lucky none got in my eyes... the case left a gash in my forearm...
One side doused in acid... clothes turned to rags before my eyes... the boss came running out and hosed me down.
/ Battery exploded, every one is ok so far #24
What????
All I can say is, you seem to have overcome the slight handicap. Anybody with 50 assorted vehicles going back to 1905 is a success in my book.
/ Battery exploded, every one is ok so far #25
Success or crazy... sometimes I wonder myself.
Always been fascinated by cars, engines, tractors... etc...
Grew up around the car business but none of the cars came through the business... thinking back of all the cars that went for nothing during the gas shortages of the 70's and what they go for now boggles the mind...
That said... I started out wanting one car from every decade... just have never been able to have them all in one place.
Hint... small cars take up less room and some have small batteries!
Batteries are the bane of collecting antique cars... I have a small army of battery tenders and they do help...
/ Battery exploded, every one is ok so far #26
Another thing to consider to be safe around batteries is this: Maybe the OP can say why it is the battery that exploded was removed from the car/truck or whatever it was being used in prior to it exploding?
I suspect that had the electrical system the battery was attached to been thoroughly examined it would likely have shown the charging system was OVERcharging it, to the point where when the charger was attached to it the critical point had been reached and it blew up.
For reference, most any system putting out more then 14.5 Volts while being tested is OVERcharging. When a system fails to control the voltage output back to the battery, because of a defective voltage regulator, whether built into the alternator or housed separately, the battery can, up to a point take an overcharge, until it can't, at which point it will explode or otherwise fail catastrophically.
A broken charging system can send overvoltage of 17+ Volts back to a battery, and boil it's internal fluids, which will create a very unstable battery that can/will explode without any warning.
Things like boiled out acid on the surfaces of a battery, along with being hooked to a shop charger can be all it takes for the acid mix and gasses produced by the overcharged battery to become a lethal combination. The acid mix can become the equivalent of putting a piece of metal like a wrench between the posts, causing a dead short and then boom. A spark is the most likely, BUT not the only condition necessary for an explosion to take place.
If there are any doubts AFTER performing an output voltage test on a battery- let it sit in the vehicle for several hours BEFORE removing it. ALWAYS disconnect ground cable first and hot cable last when removing a 12 Volt negative ground system. And when installing positive post first, ground cable last, with the ignition key off and removed from the ignition.
/ Battery exploded, every one is ok so far #27
I don't agree with the advice of charger plugged in first and unplugged last. I do the opposite. Maybe it was a communication error.
I also have made it a habit of looking away when I unclip the alligator from a battery. Also, I try and find another ground away from the battery and disconnect that first or connect last.
/ Battery exploded, every one is ok so far #28
I agree.
/ Battery exploded, every one is ok so far #29
What????
you're lucky batteries don't use Hydrofluoric acid, it burns right down to the bone in seconds..
/ Battery exploded, every one is ok so far #30
Hydrogen is about 2X lighter than Helium, so there's no way Hydrogen gas is going to stick around a battery.. it will be up to the ceiling looking to go much higher through any cracks.. if it can't then it will slowly accumulate to a lower level. if a battery is quick charged(Gassing) or a heavy discharge or short, it will gas and make Hydrogen. you could charge a battery, and an internal short inside the battery can make a large amount of Hydrogen gas, though!.. but always plug the charger in LAST, and unplug it FIRST to reduce the chance of a spark..
EDIT:I can't edit this post, but here is the correction. I don't know how this error got into there!.. but always plug the charger in LAST, and unplug it FIRST to reduce the chance of a spark..
/ Battery exploded, every one is ok so far #31
The link shows the Deltran Battery Tender instructions for lead acid battery charging. Their web site has instructions for their chargers designed for AGM and newer batteries.
It covers all the items in question, what to connect to what when, where to stand and face when doing so, etc., in detail.
This should end any confusion or tendency to follow bad habits.
http://products.batterytender.com/021-0128-man.pdf
/ Battery exploded, every one is ok so far #32
you're lucky batteries don't use Oxalic acid, it burns right down to the bone in seconds..
Are you sure you aren't talking about Hydrofluoric? I have used both; Oxalic is used as a bleach for such things as a wooden fence; Hydrofluoric is used for dissolving sand. It will go through the skin and actually dissolve the bone. It is one bad motor scooter. Worked with a guy when I was in the lab that got some on his little finger; it was mixed with some DMSO and he lost part of his finger. Bad stuff.
/ Battery exploded, every one is ok so far #33
yes, of course, I messed up.. it's Hydrofluoric acid..
/ Battery exploded, every one is ok so far #34
Yeah! Sure glad batteries don't have nitroglycerine or a bubonic plague agent in them
/ Battery exploded, every one is ok so far #35
I was wondering too... a silversmith I use has Oxalic Acid on hand for cleaning silver... seen him use it and was thinking if it could go through bone he wouldn't have fingers left.
/ Battery exploded, every one is ok so far #36
I attended a presale viewing of mostly post WWII microcars a while back. The collector who sold out got a pile of them into one building. This was somewhere down in Ga. You didn't happen to be there, did you?
/ Battery exploded, every one is ok so far #38
No… but I can fit 4 in the space occupied by the 1967 Fleetwood...
Long ago I gave up on batteries for everything.... but I probably have 25 chargers with a lot of tenders...
Ever since that one battery exploded... I am most careful not to make the last connection at the terminal... and on the old car batteries... I always check the electrolyte level first to make sure it is full.
ROADTEC RX700 MILLING MACHINE (A64279)
ROADTEC RX700...
2020 VOLVO VNL840 MIDROOF 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2020 VOLVO VNL840...
2015 Audi A4 Sedan (A61574)
2015 Audi A4 Sedan...
MASSEY FERGUSON 240 TRACTOR (A64280)
MASSEY FERGUSON...
2007 INTERNATIONAL PAYSTAR 5600 Bucket Truck (A62679)
2007 INTERNATIONAL...
2025 28in Forks and Frame Mini Skid Steer Attachment (A61572)
2025 28in Forks...
