Battery dying or belt slipping?
   / Battery dying or belt slipping? #11
When people describe your problem, I always say load test the battery. Otherwise you don’t know if the battery is good. The volts alone doesn’t tell you. A load tester is less than $50.
OK. Belt changed, no joy. Still around 12.9 volts when running. I've got a service manual but it's pretty hard for me to decipher, I'll work on it some more another day. Thanks again for the guidance!
Oh, I forgot to add that I found a sticker on the battery, 12/17. So that battery is likely gone. If it continues to have the slow starting issue I'll replace it.
   / Battery dying or belt slipping? #14
That's still young for a battery.
   / Battery dying or belt slipping? #15
Have you gone around to check/ clean the connectors and connections on the battery cables, and alternator wiring? Corrosion can give the alternator a higher voltage than what you see at the battery, which might explain the issue. What is the output voltage from the alternator when the tractor is running?
I have seen batteries fail in five years, so I wouldn't rule that one out either, but I would expect some variation on the voltage. I.e. if you charge it with an external charger, it should get to a higher voltage initially and then rapidly drop. I might pull the battery and have it load tested at an auto parts store, if you have one nearby.
Bad batteries and alternators often go hand in hand.
All the best,
Peter
   / Battery dying or belt slipping? #16
Hi,
Damn, I was hoping the belt would be it.
I think load testing the battery is a good idea.
   / Battery dying or belt slipping? #17
Does your model have a voltage regulator.
Is it adjustable, many are.
   / Battery dying or belt slipping? #18
Not for the Japan made tractors. It's the old school wire wrapped copper wires or the full solidstae types.
2016 John Deere 7210R MFWD Tractor (A53342)
2016 John Deere...
2023 John Deere 8R410 MFWD Tractor (A53472)
2023 John Deere...
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
2020 Terex RL4 Towable Light Tower (A51691)
2020 Terex RL4...
WEILER B670 FELLER BUNCHER (A51246)
WEILER B670 FELLER...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
