Battery Corrosion on a 2210?
   / Battery Corrosion on a 2210? #1
DJLX
East TN
JD 2210
With all this talk about the JD batteries leaking, has anybody had one on a 2210? Didn't know if there was a history and whether I should be on the look-out with mine.
   / Battery Corrosion on a 2210? #2
It's not so much model specific, it's primarily a function of battery quality, and the environment in which it lives. The gel filled Optimas are the clear choice to avoid this. If you ever experience this, you will regret not changing it as preventive maintenance.
   / Battery Corrosion on a 2210? #3
<font color="green">The battery that came with my 2210 really made a mess of my tractor. Even corroded the plastic hold down clamp much to my surprise. One would think that a part in close proximity to the vent caps would be made from an acid resistant plastic.
My property is rather hilly and that may have contributed to the problem. Only wished I had switched out the battery sooner, like day one!
I replaced the battery in my 2210 with an Optima that I ordered from Remy in Milwaukee.
Mike </font>
   / Battery Corrosion on a 2210? #4
I want to get an optima for my 4100. What model battery did you buy?
Mike
Do you remember which Optima battery you used in the 2210?
Thanks
Doug
   / Battery Corrosion on a 2210? #6
</font><font color="blue" class="small">( Do you remember which Optima battery you used in the 2210?)</font>
I used the Optima yellow top D51 in my 2210.
URL for Remy Optima D51
Mike </font>
2019 Ford F-350 4x4 Flatbed Truck (A55788)
2019 Ford F-350...
PULL TYPE CONCESSION STAND (A54757)
PULL TYPE...
Adams 16T Tender Body (A56436)
Adams 16T Tender...
2007 GMC 2500HD (A56435)
2007 GMC 2500HD...
BIMINI TOP FOR BOAT (A58374)
BIMINI TOP FOR...
Mini Excavator 9 Piece Attachments (New/Unused) (A59225)
Mini Excavator 9...
