Battery Cell Fluid Level Check
   / Battery Cell Fluid Level Check #1
mmranch
Crested Butte, CO
TYM T603
My tractor battery is an ATLAS BX BX110BR and is 15" wide with a flat top and two terminal posts. There is also a small looking glass hole which shows the color blue when the battery is good. There are no normal caps on the top to check cell fluid level.
But when you look at the battery flat top, there are screwdriver slots on both ends of a section of the flat top. Makes me wonder if that section somehow pops off and allows checking the cells? Are tractor batteries like this serviceable for checking the cells?
The battery still charges and the looking glass shows blue but with it's age, I'm worried the cells may be drying out.
Thanks!
I should also note that I put a screwdriver in the slots and tried to pry the section off and the battery lifted up so the section does not come off easily.
Thanks!
   / Battery Cell Fluid Level Check #3
Many newer batteries are sealed and you cannot readily add fluid. If you don't let the battery go dead it should last five to ten years.
   / Battery Cell Fluid Level Check #4
About all the batteries I have bought in the last several years have been low on electrolyte. Added distilled water to bring them up.
Thanks for the ideas! I guess this battery may be nearing the end of it's life as it's probably 12+ years old now.
John Deere 6195R (A50120)
John Deere 6195R...
2003 Lincoln LS Sedan (A50324)
2003 Lincoln LS...
17604 (A51694)
17604 (A51694)
2005 Superior Trailers VT130 T/A Vacuum Trailer (A51692)
2005 Superior...
2012 Chevrolet Captiva Sport SUV (A50324)
2012 Chevrolet...
2020 Kinze 3505 High Speed 6/11 Planter (A52748)
2020 Kinze 3505...
