Battery, cables, starter, ????????????
/ Battery, cables, starter, ???????????? #1
pharmvet
Platinum Member
North East TX
Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
Inherited a Massey 283. Been sitting in barn for several months without being used. Would not crank. Jumped it off and let it run for 30 min. Killed it and it would not crank. Took battery in and had it tested. Said it was "weak" but still good. Charged it all day. Still would not crank tractor. Would turn it over a few times and then not at all. Bought brand new battery. Cranked it first time but later would not crank it. Was told it might be my battery cables. Went to a local specialty store and had them make me hot and ground cables. Replaced old cables. Made very little difference if any. Will turn motor over a few times and tractor will crank unless its first thing in the morning.
Could my starter be bad, or are starters "all or nothing" Any and all advice is welcomed. thanks. Mike
/ Battery, cables, starter, ???????????? #2
Starter could be bad. Sound like the spring in it is bent or broken. Its about $50 to get it changed. Bring it to your local auto electric shop and they should be able to rebuild it.
New Holland LB75B Backhoe (A62613)
New Holland LB75B...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2023 VOLVO L90H WHEEL LOADER (A65053)
2023 VOLVO L90H...
2016 VOLVO DD25B DOUBLE DRUM ROLLER (A65053)
2016 VOLVO DD25B...
2019 FORD F-150 STX CREW CAB TRUCK (A63276)
2019 FORD F-150...
1997 MACK MIXER (A65643)
1997 MACK MIXER...
