Battery cable
/ Battery cable #2
I have the 1538 and mine does not. A lot of folks have had issues with internal corrosion and subsequent poor connections.
A fusible link is easy to spot- it's a smaller more flexible wire with nice silicon insulation. Typically it's about 6-8" long.
/ Battery cable #3
I noticed some corrosion on my battery clamps, cleaned them and added some of those red/green felt(?) washers to the battery posts. That seems to have controlled it.
I have been working on a little project which I plan to post on soon - Adding an inverter to the front of my 1533 TLB. I added a 2 gauge cable to the positive post, ran it up above the radiator screen to a 200 amp fuse. That was about the best place I could find to mount the fuse. Would have been better closer to the battery but Mahindra runs heavy 12-volt cables all over the place without fusing and so do car manufacturers. Well, at least the ones I am familiar with. So, I just tried to use common sense in routing, securing and protecting the cables.
I believe in fusing - PERIOD. Even added a circuit breaker in the power lead to the ignition switch on my old Ford truck after the switch separated and (D-word deleted by TBN) near caused a fire. If you've never seen a larger gauge wire shorted out in a vehicle, etc., you're doing just fine. Immediately after the short, you have a second to think, "What was that?" Then, the cable turns into a 'smoke rope' and it is panic time. The only time it happened to me, I was a 19 yr-old 'mechanic' and, fortunately, had some pliers near the battery. One good WIGGLE and SNATCH and it was over. Well, except for repairing the damage! Never happened since . . . Wonder why? And to think them dope-smokers get all excited over that stuff! Adrenalin is the ultimate "high" . . .
Quick Hitch Mini Excavator Attachment (A61572)
Quick Hitch Mini...
2021 CATERPILLAR 299D3 SKID STEER (A64279)
2021 CATERPILLAR...
ROANOKE S/A LOOSE LEAF TRAILER (A63291)
ROANOKE S/A LOOSE...
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
2020 INTERNATIONAL LT625 SLEEPER (A59911)
2020 INTERNATIONAL...
Topsoil Trommel (A57453)
Topsoil Trommel...
