Basics on concrete and cinder block walls
   / Basics on concrete and cinder block walls #11
In my area the large blocks are called ecology blocks and are the cheapest and best option for material bunks. If you plan on hiring material deliverd by dump truck a 10' wide bunk is better to be able to dump into the bunk without having to transfer the material with your tractor. You also need enough room for the truck to back into them without breaking down the edge of your driveway.
Greg
   / Basics on concrete and cinder block walls #12
I second (or third) the prefab blocks.
Cinder block isnt gonna hold up well for a material bunk IMO. All the places that sell mulch and stuff like that around here, either use the prefab blocks, or some really heavy timbers.
   / Basics on concrete and cinder block walls #13
Todays flier from Lowes advertises bag of Quickete (50 lb not 60 lb) for $1.89.
Just sayin.
PAGUY
   / Basics on concrete and cinder block walls #14
I like solid concrete walls with 2 layers of rebar. I have seen too many basement walls made of block start bowing in. Just saying....
2012 Volkswagen Passat Passenger Car, VIN # 1VWCN7A38CC043906 (A55758)
2012 Volkswagen...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2006 FORD F-350 (A55788)
2006 FORD F-350...
2007 PETERBILT 335 FUEL & LUBE TRUCK (A51406)
2007 PETERBILT 335...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55301)
2012 JOHN DEERE...
