radman1
Elite Member
- Joined
- Jul 8, 2006
- Messages
- 3,017
- Location
- midwest
- Tractor
- JD 4520, Toolcat 5610, Bobcat S300, Case-IH 125 Pro, Case-IH 245, IH 1086, IH 806
Something just doesn't seem right. The blade should not angle by itself when pushing a load, regardless of how much snow your pushing. The geometry with the loader arms are also off. The blade needs to tip back enough to ride on the shoes, whether in float mode or if just skimming the surface. Teh front edge of the shoes are slightly tipped back relative to the back of the shoe. What you describe is the blade is tipped forward so the loader arms don't scrape on the road surface. If tipped forward, the shoes won't ride over the suface. Also if tipped forward, the blade can easily catch the surface or an obstacle and trip the bottom which only compounds you problem.
I fabricated a used Meyer snowplow design for a pickup on the front of my tractor. It is held up by a chain. It can float over the terrain. The FEL arms are left up slightly (nonfloat) but the chain is kept slack.
Take to the dealer if possible and see if they can help get is set properly.
