basic electrical help - adding LED flood lights
   / basic electrical help - adding LED flood lights #11
Question: If the thing is wired to the lights, doesn't the current go through a relay from the ignition switch? if so, the current theoretically could be too much for the relay, if you put a huge light bar to replace on incandescent light, but even then not likely, no? The ignition switch doesn't carry the entire load of all the lights, does it? I have always assumed there was a relay. It would seem to take a lot of LEDs to add significant wattage to the system.
   / basic electrical help - adding LED flood lights #12
Most lights require a relay because the switch
would not last very long they are not made to
handle very many amps. With the relay installed
you can use cheap switches
willy
New/Unused 14ft Bi Parting Gate (A57454)
New/Unused 14ft Bi...
2000 CASE 580SL II Backhoe (A59213)
2000 CASE 580SL II...
2808 (A58376)
2808 (A58376)
2002 International 9200i Truck (A56438)
2002 International...
Kubota B7510 (A57148)
2025 YOUERT YOU12 1-Ton Mini-Excavator with dozer blade (New/Unused) (A59225)
2025 YOUERT YOU12...
