Basement humidity levels
/ Basement humidity levels #1
NewToy
Ohio
'05 Farmtrac 270DTC
Anyone know what is an acceptable level of humidity in the basement? Mine runs around 65 % with the ductwork vents opened up down there. It's just a few points higher than the house usually is. I was wondering what a good rule of thumb humidity percentage would be.
John
/ Basement humidity levels #2
I would think it depends on what feels comfortable for you.
My basement (below grade) usually runs about 55%, first floor about 45%, and third floor about 59%.
For myself, under 50% feels most comfortable. Keep in mind, same temp but different humidity level can actually make you feel more "warm" due to moisture in the air. Run 74 degrees at 40% and then at 65%, for myself, I can feel the differece too easy.
/ Basement humidity levels #3
I run a dehumidifier in my basement set at 55%. If I set it any lower, it runs constantly. I keep the humidity as low as I can to prevent rust and corrosion on the electronic toys that I keep down there.
/ Basement humidity levels #4
John
Mornin John,
I keep my dehumidifier running for the most part all spring and summer, because I have my woodworking equipment and machines in the basement. To have that stuff start to rust is not acceptable, so I just keep it running ! If you had boxes down there, you dont want them, to become damp and or moldy ! Soon as fall comes along with the cooler weather I can run the woodstove to eliminate any moisture in the basement !
My basement always stays right around 65 degrees with 60-65% humidity. I keep the AC set at 72 in the house and humidity levels are running around 55%. Was just wondering if those were acceptable levels, don't want to have a mold issue down the road.
Thanks,
John
/ Basement humidity levels #6
Not sure what the right level should be but I've always run a dehumidifier in the summer months. The basement is so much cooler, when it's comfortable upstairs, the moisture is condensing all over in the basement. Like others, I have woodworking equipment and such down there that I prefer not rust.
/ Basement humidity levels #7
I have a 120 gallon retention tank in the basement. Without a de-hu the thing sweats bad. The doors in the house will warp so bad they won't close. So this time of year I'm doing 25 pints of water a day.
Guns started rusting too so I had to move them upstairs. I would say under 55% is the place to be in.
/ Basement humidity levels #8
Another thing you can do (surprsed it's not as commonas it shoudl be) is if you have central A/C to put not just a supply vent down there but also a return vent to suck the damp air out.
Often in an unfinished basement there isn't a return air vent just maybe a supply vent usually cut into the side of the duct somwhere.
2014 Caterpillar 308E2 CR (A64126)
2014 Caterpillar...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A63276)
2018 FREIGHTLINER...
2012 Allmand Bros. Maxi-Lite SHO-HD Light Tower 20KW (A63689)
2012 Allmand Bros...
2015 Chevrolet Silverado Flatbed Truck, VIN # 1GB4KZC87FF627659 (A65563)
2015 Chevrolet...
Club Car Emergency Cart (A64557)
Club Car Emergency...
NEW HOLLAND TS115A TRACTOR (A62130)
NEW HOLLAND TS115A...
