BARTER Kubota mid PTO kit 2753 for 2752 kit
   / BARTER Kubota mid PTO kit 2753 for 2752 kit #1
Tollster
Benton, Pennsylvania
Kubota, BX23
I'm ready to move on a blower with the 2753 PTO kit, which is too long for my BX 23 TLB, looking to see if anyone has the shorter 2752 shaft kit that needs the longer one?
Thanks,
Tol
   / BARTER Kubota mid PTO kit 2753 for 2752 kit #2
you do not need to replace the entire $700 kit. There is a single shaft segment that's different between the two. Its under $150 as I recall.
Thank you, I spoke to Dave in parts and he spoke to Loren in sales, very knowledgeable staff there in Etown. Got the shaft part number today. Thank you very much!
   / BARTER Kubota mid PTO kit 2753 for 2752 kit #4
I'm in the same boat as Tollster. I just bought a blower with the 2752 kit.
I need the 2753 kit as I am mounting it on a BX25.
Is there an easy place to find the part number of this correct shaft?
Thanks in advance!
   / BARTER Kubota mid PTO kit 2753 for 2752 kit #5
Go to Kubota.com. Select "Parts". Sign the agreement to proceed.
Enter BX2751 in the Search box Several Options will appear. You want the one at the bottom for the higher serial numbers. Select the Link under the "Book" Heading. Another window will open but no images will be displayed yet. Expand the Tree in the left hand side of window. Once expanded you'll find the desired drivetrain. Select the one you want and a parts drawing will appear along with a parts list.
I'd supply a direct link but it doesn't work. This will get you to the Term/Conditions page. http://www.kubota.com/part/partsList.aspx
Hope this helps.
You can buy the shaft with yokes or just the shaft and transfer the u-joints and such from the shaft you have
EDIT: Added Photos and pricing
70060-02186 Assembly $254.85
70060-02338 Shaft Only $131.38
(Prices per Messick's website)
   / BARTER Kubota mid PTO kit 2753 for 2752 kit #6
Trade 2752 pto for a 2753 pto
   / BARTER Kubota mid PTO kit 2753 for 2752 kit #7
Thanks,
Tol
I know this has been sometime now and you've probably already found the shorter shaft that you were looking for. By any chance do you still gave the langer shaft and do you want to part with it?
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
MASSEY FERGUSON 492 TRACTOR (A51406)
MASSEY FERGUSON...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A53472)
John Deere 6105E...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
